Computer Chips & Tuners
2 questions
Old Mar 5, 2004 | 11:40 AM
majorpecs's Avatar
majorpecs
2 questions
I have a 2000 F250 7.3l Turbo Diesel. I attained the Bullydog 4 bank switch with the on-the-fly switch. I have a stock exhaust system, and a friend suggested just buying a cut-out to use when I wanted to run the chip at the +110 setting. And that my stock exhaust was fine for the 50 or 80hp settings. Is this information correct???? Thanks for any help!
Old Mar 6, 2004 | 11:04 PM
FTE Ken's Avatar
FTE Ken
It should be fine with the 50HP. 80HP should be fine when not towing except at high altitudes. I don't think a cut-out is the way to go, you need the larger exhaust not only for better air-flow but also for its ability to dissipate heat faster. I don't have enough data about Bullydog 110 settings to give a 100% qualified answer and I recommend you contact them directly.
Old Mar 8, 2004 | 11:55 AM
majorpecs's Avatar
majorpecs
Thanks Ken....I admire you dedication to this site by responding to everyone. One clarification for myself, you saying I should be fine at 50, and 80 (no towing) with the cutout or just stock?? I guess my problem is that I don't have $400 right now to buy an exhaust system. Would a cold air intake suffice?
Old Mar 8, 2004 | 03:39 PM
openclasspro's Avatar
openclasspro
i'd venture to say it will lean out the a-f mixture some
67fordok
2009 - 2014 F150
Mar 16, 2014 09:04 AM
wedefyu
Apr 6, 2009 06:27 PM
deepsouthdrilling
Apr 2, 2008 12:01 AM
nick6160
New Member Introductions
Jun 4, 2006 03:49 PM
adamshee
Jul 19, 2005 11:17 PM
