Anyone Using Bullydog On Your 6.0L?
Just was wondering if anyone has experimented with any bullydog products. A few guys around here are using bullydog chips cause there is a dealer near that sells them. The are having excellent luck with them and are stacking them with a programmer. The guys around here are the only people I've seen use them. Anyone on here try it yet?
As for the Bullydog units, we have an early FICM piggyback unit on our 2003 F550 AATAC Slideback, and it has worked great. The early units had the same shifting problems as some of the units now, but the truck is a manual so we have never had any problems. It makes great power, and so far it has not failed like most of the earlier units. I would say if that is what you are looking for, go for it, they are good solid units. Go find yourself another dealer that sells them, and take a look at thier dyno dominator boxes and the outlook monitor.
I agree with you PSD, stacking untis not meant to go together is a no no. I wonder if SC could custom burn a chip to be matched with a juice/attitude combo?
IF you can get them to do it, I think it will work GREAT. The two behave nearly to the opposite of one another, and if you could combine them, the entire powerband will be ridiculous.
Originally Posted by obxdieseldoctor
psd for some reason i cant respond to your pm i can rad it but every time i resspond it says invalid user,i think pan got the info hope he will share the info with you,if he cant let me know and il try again in a few days.
bullydog is a good dog
Yeah I installed Bullys unit on my 01/04 PSD CC IT HAS 3 SETTING STOCK/65 H.P. AND 115H.P.VERY GOOD Preformance considering the time and exspense involved.The 115 setting seems to pop and spit under full throtle at first then it runs like a bat....The installation is alittle involved and the unit does need to be removed before any service work is done.I usually keep it at the 65 h.p. level so as not to create to much confusion to the processing unit .Apparently, The truck seems to like having it set at one level and not constantly changed from one setting to another.MPG was impresive at first but, then it seemed to drop off some.Maybe alittle to heavy on the load pedal or reflash may have been the cause.I dont know anyway 14 mpg city and 16 hywy not all that bad for a 8 ft bed (LWB) crew cab with cap
lawdawg79
11-20-2015 04:17 AM
