hauling ?
Old Sep 14, 2007 | 01:33 PM
truckman01's Avatar
truckman01
hauling ?
2007 Ranger 3.0L 5 speed with trailer hitch. Will this truck handle hauling a 4000lb camper? Will the rear suspension be fine or is there any mods to be done for this weight?
Old Sep 14, 2007 | 05:52 PM
wendell borror's Avatar
wendell borror
You should have 4:10 gears, that would help. If you have a 5 speed manual, it's only rated for 3,500 I believe, however it will will as much as an automatic, but ford tries to avoid warrenty issue's. If it were me, I'ld pull it, I've pulled 5 and 6,000 pounds with my truck and I have a manual, but it's up to you. Gears would help and be eaiser on the clutch if you have or get 4:10's.
Old Sep 14, 2007 | 09:48 PM
sfcwoodret's Avatar
sfcwoodret
I agree. I would also look at upgrading your tires if you have those Continentals.
Old Sep 15, 2007 | 10:38 PM
CougarXR02's Avatar
CougarXR02
agree with everything so far. the suspension is ready for it. I pull a 4150# dry weight fifth wheel with my stock 99 on stock 225/70-15 tires. 60,000 on the original firestone wilderness HT's, now running Bridgestone Dualer A/T's.
It goes without saying but make sure you have a trailer brake control unit installed. more advice on that can be found in the towing forum.
Old Sep 15, 2007 | 11:54 PM
Bear River's Avatar
Bear River
Former ******
The Aerostar is rated to tow 6,000+ and its not even a truck. I would think you could handle that trailer. Just make sure you don't pull any grades in overdrive.
Old Sep 16, 2007 | 10:47 AM
ranger1999 Bob's Avatar
ranger1999 Bob
ive towed that kind of weight with my four banger with an automatic and its been just fine just go easy on the grades
waystro
17
Apr 1, 2015 09:20 PM
KP1001
Feb 26, 2013 04:48 PM
frankmako
Dec 11, 2011 08:22 PM
sammy77
Nov 12, 2010 06:47 PM
barnestormer
Sep 21, 2007 03:46 PM
