Sponsored by: Auxito
P1-1299 code
Old Sep 13, 2007 | 07:16 AM
geomorton's Avatar
geomorton
Question P-1299 Code
My truck brought up a P-1299 code. So i change the water temp sen to the computer. new thermostat, new fluid. Seemed to work for a day. Then on the way to work the heat goes away the temp gauge goes to high and the oil light comes on for about 30 secs. then everything goes back to norm. Confused?
Old Sep 13, 2007 | 08:38 AM
projectSHO89's Avatar
projectSHO89
It would help if you completely identified what you're working on.
Steve
Old Sep 13, 2007 | 10:17 AM
geomorton's Avatar
geomorton
P-1299 code
Define the P-1299 code
Old Sep 13, 2007 | 10:26 AM
KingRanchMan02's Avatar
KingRanchMan02
https://www.ford-trucks.com/article/idx/7/247/article/Ford_OBDII_Diagnostic_Trouble_Codes__P1000P1999__C odes_Specific_to_Ford_vehicles.html
What model year, model, engine, and transmission do you have. Truck details are very helpful when it comes to helping you with your questions. Good luck!
Old Sep 13, 2007 | 11:09 AM
geomorton's Avatar
geomorton
The truck is a 97 F-150 4X4 ext. cab 4.6 V8 automatic with over drive I do not know what tranny it has
Old Sep 13, 2007 | 11:13 AM
projectSHO89
Diagnostic Trouble Code (DTC) P1299 indicates an engine overheat condition was detected by the cylinder head temperature (CHT) sensor. An FMEM Strategy called Failsafe Cooling was activated to cool the engine. (Refer to Section 1A, «Electronic Engine Control (EC) System», for more information on Failsafe Cooling Strategy and the cylinder head temperature sensor.)
Possible causes:
-- Engine cooling system concerns.
-- Base engine concerns.
-- Low engine coolant level or loss of coolant.
l Check engine coolant level.
l Is the engine coolant level fill correct?
Yes
GO to the Powertrain/Engine Group, Engine Cooling System Section in the Workshop Manual for symptom, Engine Overheats.
No
GO to the Powertrain/Engine Group, Engine Cooling System Section in the Workshop Manual for symptom, Loss of Engine Coolant.
Old Sep 13, 2007 | 01:34 PM
geomorton's Avatar
geomorton
When the truck give the code I read it with a scanner. So I replaced the coolant sensor to the computer, installed a new thermostat and coolant. I will check the levels. Thanks for the help!
Old Sep 14, 2007 | 04:53 AM
geomorton's Avatar
geomorton
Project; I have had 2 different scanners on it when it read P-1299 they both said something to do with air monoriting. I do not have access to any manuals.
Old Sep 14, 2007 | 05:22 AM
geomorton's Avatar
geomorton
Question P1-1299 code
Gentlemen; When My 97 F150 4.6v-8 4X4 issues a p-1299 code it does not say anything about overheating it says somthing about air metering. Here is what the truck does. From a cold startup about 2 to 3 miles the temp gauge will come up quicker than norm. It will show at norm operating temp, then it will start do drop. The oil temp light will come on then the water temp gauge will go strait to high temp in the red for about 30 secs. burp the fill tank and then go back to norm.It will not do it after you have drivin for a little bit.I have replaced the water pump, thermostat, coolent and the water temp sensor to the computer.I have also notice the gas mileage decreasing. Thanks for Your Help.
Old Sep 14, 2007 | 06:41 AM
projectSHO89
If you're getting an P1299 fault code, then the description presented by the scanner(s) is erroneous. I've given the Ford definition that is specific to YOUR truck, not a generic description.
I'd be suspicious you have a faulty head gasket. A test for exhaust gasses in the coolant would be worthwhile to either verify or rule out this as a possibility. If your mechanic has an exhaust gas analyzer, he can hold the probe above the open radiator neck, run the engine at 1500 RPMs, and see if the sniffer picks up anything. If you used any type of radiator flushing agent, be sure to tell him first as the petroleum in these products will give a false positive.
Alternatively, you can go by any local NAPA store and purchase a block tester kit. About $50 - part number 700-1006.
Please avoid starting a new thread as a continuation for the same issue. Keep everything in one place.
Steve
Old Aug 3, 2009 | 11:43 AM
possun33's Avatar
possun33
My truck (same as yours) is doing the same thing. What did you find out was the problem?
Old Aug 3, 2009 | 06:31 PM
pintopower8's Avatar
pintopower8
ummm I'm thinking you better start looking for a head gasket or a cracked head......The sooner you start looking the better.....
scooter71
3.8 & 4.2L V6
63
Jul 25, 2018 11:27 PM
SBWoobs
Aug 14, 2017 11:22 AM
z31freakify
Sep 15, 2015 07:08 PM
radiorob
1997 - 2003 F150
Jul 2, 2012 08:29 AM
drf150
1997 - 2003 F150
13
May 14, 2012 08:44 PM
