Sponsored by: Real Truck
Need help! eratic temp gauge
Old Sep 15, 2015 | 01:02 PM
z31freakify's Avatar
z31freakify
Im working on a 2005 f250
2wd 5.4 3v truck.
I installed a long block jasper and having problems with the temp gauge, for some weird reason it keeps climbing to the red mark and keeps beeping and the display says check gauges. I was not having problems with the old engine.
The engine is not running hot for a fact, what do you guys think it is.
I have two codes p1285 & p1299 i know there was a tsb on this but like mention earlier, the old engine never had this problem.
Help apreciated
Old Sep 15, 2015 | 03:37 PM
davester250's Avatar
davester250
temp sensor works differently than the truck computer/gauge expects?
Old Sep 15, 2015 | 05:55 PM
Chuck's First Ford's Avatar
Chuck's First Ford
sensor,, wrong, defective, air pocket in system... damaged wires.
How do you KNOW the engine is NOT overheating?... or has HOT spots...???
you using an Infrared thermometer???
Old Sep 15, 2015 | 07:08 PM
z31freakify
Yes sir i used an Ifrared, but i think i found my problem. Apparently when ever i installed the intake manifold a crushed the CHT wires and, exposed wires were touching the cyl head grounding them. Thanks for the responses gents.
meck1
1983 - 2012 Ranger & B-Series
Oct 23, 2018 08:38 AM
chrislynn5
May 1, 2016 07:04 PM
bryantperry
3.8 & 4.2L V6
Dec 2, 2010 01:36 PM
Eric1967
Oct 25, 2007 09:53 AM
dragford
Jan 17, 2007 11:47 AM
