Aerostar Ford Aerostar
FINALY changed them.
Old Sep 14, 2007 | 12:59 AM
DCRB's Avatar
DCRB
yup, finaly changed my brakes, put brand new rotors and pads and fully rebuilt calipers installed and supercleaned the bearings with grease then repacked them... then took it to my local midas to have brakes inspected (just to be safe) and they pulled my drums off and showed me that the previous owner put the shoes on backwards.... lol. i didnt think that was possible? but yeah retourqed everything to spec and it rides great... BUT... midas said i didn't grease something? idk... something about greasing the calipers... but when i pulled off my old calipers they were dry... so was that maybe a way that i could give them business? also, does any one know if they do good muffler/custom pipe jobs?
THANKS!!!
p.s. i'm fixing those shoes on saturday... doesn't rly effect my stoping with my new brakes tho...
Old Sep 14, 2007 | 03:50 AM
96_4wdr's Avatar
96_4wdr
get a Chiltons or Haynes Aero repair manual at your local parts store or google disk brake caliper repair
use only grease rated on tube for brakes high temp.
wire brush slide areas first
put in new slide pins from parts store.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Sep 14, 2007 | 05:44 PM
DCRB's Avatar
DCRB
http://www.autozone.com/az/cds/en_us/0900823d/80/14/c6/51/0900823d8014c651/repairInfoPages.htm
http://www.autozone.com/az/cds/en_us/0900823d/80/14/c6/d9/0900823d8014c6d9/repairInfoPages.htm
uh... ok. i just used (for now, can/will change them if needed) the old slide pins cuz i didn't see them chillin in the box till AFTER i got my car all put back together... so i guess i'll do that this weekend when i fix my rear drum then. lol
thanks!
edit: why's it bad to use the old shims?
Old Sep 14, 2007 | 09:29 PM
96_4wdr's Avatar
96_4wdr
the synthetic rubber breaks down decreasing the tension
the stop tabs wear down
plus new ones just barely function correctly all lubed up
sammyhawk
1997 - 2003 F150
Aug 22, 2012 07:46 AM
mybigredford
Jan 30, 2012 11:17 PM
DCRB
Aerostar
23
Nov 26, 2007 04:29 PM
BeckerSD
Jun 29, 2004 09:59 PM
jhromy
Feb 3, 2004 08:35 PM
