Coolant Flow Restrictor
Old Sep 13, 2007 | 11:35 PM
s knox's Avatar
s knox
I am finishing up the 351 and need to know where I can purchase the coolant flow restrictor. No luck at NAPA. I understand this is necessary? Thanks in advance.
Scott
Old Sep 14, 2007 | 01:02 AM
grclark351's Avatar
grclark351
if it's a Cleveland, here's a lead. if it's a 351M/400, they are cast into the block, it's not a removable piece.
http://www.network54.com/Forum/11941...ad/1181003900/
Old Sep 14, 2007 | 08:36 PM
s knox's Avatar
s knox
Smile Thanks grclark
Thanks for the info. It is indeed a Cleveland. This was a new one to me. Are they necessary and how do they help cooling.
Scott
Old Sep 15, 2007 | 03:16 PM
grclark351's Avatar
grclark351
first, are you sure it's missing? necessary? yes! they are critical to be in place for the cooling system to operate properly. here's a link to a great explanation of how the bypass system works, http://www.are.com.au/feat/techt/thermostat.htm
here's a pic of the restrictor installed in the block,
if you don't have a round brass thing that is press fit into the block, you need one. if you have it, you have it. the thermostat is special to work with the restrictor, as described in the first link.
Old Sep 15, 2007 | 05:32 PM
53fatfndr's Avatar
53fatfndr
Where would one get one of these if it is missing? I looked on Tim's website, but I didn't see any listed.
EDIT: I see you posted earlier in a post that it is cast into the block. I've heard of people actually missing theirs. This doesn't make sense if it is cast into the block.
Old Sep 15, 2007 | 08:45 PM
s knox's Avatar
s knox
Coolant Restrictor
Thanks again grclark. Mine is definately missing. I will get one ordered and check out the info.
Scott
Old Sep 15, 2007 | 08:59 PM
53fatfndr's Avatar
53fatfndr
Scott
Let us know where you find one.
Old Sep 16, 2007 | 12:53 PM
grclark351's Avatar
grclark351
53, here's the lead again,
there's a Email addy in there so i don't want to post it here and get it deleted. there's another solution that allows you to use a Windsor/generic type Tstat,
http://www.network54.com/Forum/11941...ad/1170725259/
and again, the 351M/400 block was designed to eliminate the pressed in part, the block is simply cast with the restrictor. maybe Ford was thinking that they might want to experiment with the size of the Cleveland restrictor for "off road" purposes?
Old Sep 16, 2007 | 02:31 PM
53fatfndr's Avatar
53fatfndr
Thanks for the links.
developer
Feb 3, 2015 08:33 AM
Midnite1987
26
Jan 3, 2012 01:27 PM
puffen:D
13
Jan 16, 2008 12:57 AM
Dialtone
May 17, 2003 09:21 PM
whaynes
26
Apr 21, 2003 03:37 PM
