Sponsored by: Real Truck
Fog Lights
Old Sep 13, 2007 | 08:02 PM
F350-6's Avatar
F350-6
Fog Lights
Anyone know how many watts the factory fog light put out? I used to think they were a waste of money, but I drove the wifes truck with fog lights the other morning and am thinking of adding some to my truck.
I've got a ranch hand replacement bumper so I'm looking at the round bolt on (KC type) aftermarket lights. I just don't know what wattage I should be looking for.
Old Sep 13, 2007 | 08:10 PM
DCSpecial's Avatar
DCSpecial
I believe the stockers use a 42w bulb (9145 bulb).
I run a 9005 bulb in mine (60??w, if I remember correctly).
Old Sep 13, 2007 | 08:19 PM
F350-6's Avatar
F350-6
So the 55W lights I can get for $10 ea. shouldn't be too much. Now I just need to figure out where to wire them in so I don't accidentally leave them on with the key off and kill my batteries.
Thanks for the help.
Old Sep 13, 2007 | 09:45 PM
i eat hybrids's Avatar
i eat hybrids
i run 55w and there perfect.
Old Sep 13, 2007 | 10:29 PM
RACERX7775's Avatar
RACERX7775
$10 lights. sorry. JUNK. you have a $$$$$ truck and you are going to ruin it by installing a set of $10 lights on a $1000 bumper? do yourself a favor and get a set of good lights.
Old Sep 13, 2007 | 10:33 PM
i eat hybrids
I use the silverstars $45.00 at autozone
Old Sep 14, 2007 | 06:22 AM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
I have a question. I have foglights on my truck and the switch don't go to the foglight symbol on the dash. Can someone tell me whats up with that.
Old Sep 14, 2007 | 06:27 AM
riggz's Avatar
riggz
It doesn't pull out?
Old Sep 14, 2007 | 07:16 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Pull out to turn the fog lights on, unless the switch went out before you got the truck and the saved a few bucks by buying the non-pullout style?
Old Sep 14, 2007 | 08:30 AM
aldridgec's Avatar
aldridgec
The switch isn't supposed to turn to the symbol. It is trying to indicate for fog lights pull, but imo doesn't do a good job.
Old Sep 14, 2007 | 08:54 AM
sflem849's Avatar
sflem849
Any probs getting the highbeam flash or when actually in fog with the 9005's? I believe the 9005's said they were a high beam light. I just got 9006's and 9007's for my truck and the 9006's dont fit.
Old Sep 14, 2007 | 09:22 AM
jomac11's Avatar
jomac11
9005 is a low-beam bulb, commonly used in GM vehicles. The 9006 is a high-beam bulb. My neighbor's fog lights burnt out in his 01, so we put in the 9006s that I had from my old chevy . I would however reccomend the 9005s, as the 9006 bulbs caused a little bit of melting on the inside of his fog light lenses.
Old Sep 14, 2007 | 09:29 AM
i eat hybrids
i dont think the 9006's fit the stock casing.
Old Sep 14, 2007 | 10:47 AM
sflem849's Avatar
sflem849
Yeah, I stole mine out of a Grand Am that blew up. The high beams fit and the low beams didnt, but from what I saw here both should fit. The low beams also had to have a ridge ground out of the middle from what I learned here. I will research it a bit more and see what I can find. I am not the biggest fan of running high beams in there either.
EDIT - I lied earlier I have 9005 and 9006 and only the 9005 worked. The 9006 needed to be ground out and they wouldnt lock in. But I would assume the 9006 are a low beam and the 9005 a high bc the 9006 had the same grey plastic on the ends that the fogs had.
Old Sep 14, 2007 | 06:29 PM
GregsSD's Avatar
GregsSD
I run the 9006 in mine, and I did grind out a little to make them fit and they work fine.
I used silverstars and the fogs work much better than stock!
