Throttle Pedal Problem
Old Sep 14, 2007 | 07:42 AM
Action4478's Avatar
Action4478
Originally Posted by MATTRESS GUY
Which Wire Is Your Money On?? The O/d Wire Or The One That I Had To Splice For The Exhaust Brake???
The spliced one.....
Old Sep 14, 2007 | 07:43 AM
Action4478's Avatar
Action4478
The play ,or delay in the pedal can be adjusted also.....
Old Sep 14, 2007 | 07:46 AM
MATTRESS GUY's Avatar
MATTRESS GUY
How Do U Adjust The Play???
Old Sep 14, 2007 | 07:47 AM
Action4478's Avatar
Action4478
Testing the TPS......
You need to put a voltmeter across the GY/W and the GY/R wires on the connector to the TPS. With the key on, watch the voltage across the range of the throttle to see if there is any flat spots. You should see no less than .37 volts at idle position and no more than 4.5 volts at full throttle. The the third wire, (BRN/W), is the ref. voltage and should be 5 volts all the time.
Old Sep 14, 2007 | 07:50 AM
rbaker6336's Avatar
rbaker6336
the wire that was spliced
Old Sep 14, 2007 | 07:56 AM
Action4478's Avatar
Action4478
....Here are some instructions....
Old Sep 14, 2007 | 09:30 PM
Clint40's Avatar
Clint40
Matress guy when you put in your TS chip did you remove the pcm from the fire wall on the engine compartment driver side?? I did this because I had to access a wire to tap into and when I did I pulled a wire from my pedal assembly and never knew it until I tried to give it the gas (diesel). I then had to trace which wire and push it into the pcm to make contact. I wonder if you have something similar going on but its shorting somehow???
SBFD8
17
Dec 27, 2025 01:50 PM
BigRedWeather
19
Sep 4, 2016 06:56 AM
AKHunter93
35
Dec 19, 2015 06:02 PM
Zach_Dearing
Jan 6, 2015 12:29 AM
waskin27
Apr 26, 2011 01:54 PM
