Reinstalling Injectors
Old Sep 14, 2007 | 07:15 PM
Action4478's Avatar
Action4478
Originally Posted by RÖENTGEEP
To clarify to me, are thouse wich you can use to de HPX fitting?
I thought the HP was for fuel...
I've been wrong before.....
Hopefully someone will straighten me out....
Old Sep 14, 2007 | 07:22 PM
Action4478's Avatar
Action4478
HPX mod must be for oil ...As in .......the name of the mod.....
If true , the plugs in the head would work.....
Do we have an emicon for stubidoo......
Old Sep 14, 2007 | 07:54 PM
plowhand's Avatar
plowhand
Playing in the Dirt
RÖENTGEEP, yes they are.
Action4478, the HPX mod, is a High Pressure Crossover line that connects both oil galleries (one in each head) together. The purpose is even out the High Pressure Oil in both heads, since the normal set up has the ICP reading the oil pressure in only the left (drivers) head. This smooths out the idle and gives a little better throttle response.
Old Sep 14, 2007 | 08:13 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Ditto about the HPX by Plowhand, and thanks for answer my question Plo.
Old Sep 15, 2007 | 09:55 AM
Action4478's Avatar
Action4478
Thanx Eh. Long day (brain fart) I knew what is was , but I don't hear much about it lately... I had it confused with the "cackle " cure in my head on the newer motors, which I hear about all the time ,,,
My bad....
