Need Help with Newly developed Stalling
Old Sep 13, 2007 | 10:20 AM
kev-n-gina's Avatar
kev-n-gina
I have A 99 f-250 Powerstroke with 120 and change. No mods-ever I have owned from day one. All of the were filters changed @ 114968 Miles, I keep a log and do all work on the truck myself. Alternator, leaf springs and ball joints are all that was ever required outside of normal maint.
Yesterday on the way to work (1 time) and this morning on the way to work (2 times)
truck has stalled on deceleration, I shifted to neutral and started right back up. Yesterday I stopped and put some fuel in, as it was low enough the light came on. No problems going home. The second time this morning there was a hick-up if you will which immediately set the Check engine light on. Light did not come back on after restart @ work.
I believe I have noticed a slight loss in
power over time but assumed this was Turbo fatigue and the fact the truck has 120k on it. Now I wonder if I have an injector pump issue or possible a fuel delivery issue.
Any advise is appreciated
Kevin
Old Sep 13, 2007 | 10:25 AM
rbaker6336's Avatar
rbaker6336
CPS would be first thought
Old Sep 13, 2007 | 10:32 AM
kev-n-gina's Avatar
kev-n-gina
Ok Forgot to add it has been a little colder in the mornings here over the last couple of days...........Would this increase the chances of it being the "CPS"
Old Sep 13, 2007 | 10:33 AM
Beast01's Avatar
Beast01
X2. You can get a CPS(Cam Position Sensor) for between $15.00-$25.00 most places. Good luck keep us posted. At least you can still start yours....
Old Sep 13, 2007 | 10:57 AM
Alpine6's Avatar
Alpine6
Change out the CPS. If that doesn't fix it, UVC Harness inside one of the valve covers. Check out www.7point3.com for right ups on each.
Matt
Old Sep 13, 2007 | 11:37 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Instructions for changing out the CPS. Takes longer to round up the tools than it does to change.
http://guzzle.rbmicro.com/cps.html
Old Sep 13, 2007 | 12:17 PM
bdrummonds's Avatar
bdrummonds
X 5, on the CPS. As for the losing power over time, check your boots for a boost leak, the clamps have a way of loosening over time. check your up pipes (to the turbo from exhaust manifold) for leaks also.
Old Sep 13, 2007 | 12:23 PM
rbaker6336's Avatar
rbaker6336
I had problems with boots leaking even with tight clamps,never got full boost til all boots were replaced
Old Sep 13, 2007 | 12:42 PM
bdrummonds's Avatar
bdrummonds
Good point Ray, sometimes the boots do develop pin holes. Kev, also check to make sure your waste gate actuator is adjusted correctly and is closing off completley.
Old Sep 13, 2007 | 12:52 PM
kev-n-gina's Avatar
kev-n-gina
Ok Just put in a new CPS. Piece of cake...Also Changed the oil (it was a little low and due for it).
Still has less power then I remember it having. Don't get me wrong it still runs strong just not as strong. I remember the days.... Little cloud above my head...sunshine and daisies... when this thing would set you back in the seat from a roll.
Any quick and easy ways to check for leaks? like checking for intake manifold leaks with a can of carb clean.
How about the wastegate do I need to pull it loose to verify proper seating
Old Sep 13, 2007 | 12:59 PM
rbaker6336's Avatar
rbaker6336
I found when I changed turbos the old one had very little spring pressure
tightened new one before installing
Old Sep 14, 2007 | 08:00 AM
kev-n-gina's Avatar
kev-n-gina
No stalling this morning. As of now I am going to say that wa it seems that the idle is a little smoother no more power though but hey I would rather have the reliablity then the power.
Thanks a ton everyone
SeminoleSlim
25
Jul 15, 2008 10:32 PM
CheaperJeeper
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 29, 2007 11:06 PM
gsg1970
Mar 14, 2007 04:19 PM
CheaperJeeper
Washington Chapter
Jan 13, 2007 01:32 PM
