7.3 IC vs. 6.0 IC
Old Sep 12, 2007 | 10:22 PM
bdrummonds's Avatar
bdrummonds
7.3 IC vs. 6.0 IC
I have the original 7.3 IC that has the Alum end caps and tube connectors, but while contemplating the 6.0 IC I noticed they all have the rotomolded plastic endcaps and inlet/outlet. Is this a bad thing? I know the 6.0 IC flows more air and will reduce EGT's, but I just can't get past the plastic look of it.
what do yall think.
On edit: Yes I know I could order a new Spearco, or a Big DIIC, but I just don't have that kinda cabbage to spend right now.
Old Sep 12, 2007 | 10:52 PM
Pocket's Avatar
Pocket
Once it's in, you'll hardly ever see the plastic ends. Also plenty of folks have been running 40 lbs of boost through them without a problem. Go beyond that and there have been a few who have blown out the intercooler ends.
I guess the looks of the black plastic all comes down to tastes. But for functionality it's fine, especially for stock injectored trucks.
Old Sep 13, 2007 | 01:46 PM
John311t's Avatar
John311t
The ends of the radiator are plastic. So if your worried about the looks, just think it will match better lol.
Old Sep 13, 2007 | 04:04 PM
bdrummonds's Avatar
bdrummonds
Whatchu talkin bout Willis?
Mine are metal, Intercooler has metal ends, radiator has metal ends, A/C condensor is all metal, tranny cooler is all metal.
I'll post pics in a bit.
Old Sep 13, 2007 | 06:32 PM
bdrummonds's Avatar
bdrummonds
Here are pics
Old Sep 13, 2007 | 08:44 PM
John311t's Avatar
John311t
Woops, my bad, the top and bottom are plastic not the sides. Sorry about the confusion.
Old Sep 13, 2007 | 10:03 PM
CSIPSD's Avatar
CSIPSD
LOL... No worries on the plastic, but dont expect anything great from a 6.0 swap... I saw less then a 50 drop empty... not worth the time...
Old Sep 13, 2007 | 10:08 PM
Tenn01PSD350's Avatar
Tenn01PSD350
That's the post that I was looking for in another thread. Thanks. In the end though, when you are pushing it, I suppose it makes a diff but not for me right now.
Old Sep 14, 2007 | 10:01 AM
F250_'s Avatar
F250_
I think you hit the nail square, Tenn. Obviously, when not pushing, and even when pushing some, the existing 7.3 unit does a fair job. I would only expect the 6.0 unit then to make it's biggest impact when pushing beyond "normal" driving.
Old Sep 14, 2007 | 02:13 PM
Pocket's Avatar
Pocket
That is correct. And it's also true for the other aftermarket intercoolers as well.
Joe and I have had different results with the 6.0L intercooler. On my truck, max EGT's dropped 100 degrees due to the intercooler alone. That's on a WOT run in the highest chip setting. Normal daily driving while empty, there's not much of a difference in temps. Towing, yes there is a difference when I'm going up mountain grades, about a 75 degree drop.
I think the biggest reason our results with the 6.0L intercooler was so different is I believe it starts losing it's efficiency when you upgrade the injectors. If you stay with stock injectors, then the 6.0L I/C will work just fine. But with larger injectors adding fuel and bigger turbo pushing more air, the 6.0L cooler is just too small.
Old Sep 14, 2007 | 05:17 PM
fordf350crazy's Avatar
fordf350crazy
Has anyone thought about putting some electric fans on the IC for more cooling?
Old Sep 14, 2007 | 05:44 PM
CSIPSD's Avatar
CSIPSD
You would just plug up air flow at higher speeds when the IC can work the best...
Old Sep 15, 2007 | 01:05 AM
jtharvey's Avatar
jtharvey
That's about the same thing I saw when I dropped in a stock 6.0 IC a couple years ago. Not much difference when empty, but a little EGT drop when towing or loaded.
Old Sep 15, 2007 | 01:21 AM
Tenn01PSD350
So not worth it or what? Might as well go Spearco? What is the consensus?
Old Sep 15, 2007 | 07:37 AM
Pocket's Avatar
Pocket
It all depends on your mods. With the combination of the 6.0L I/C and turbo, I can only hit 1200 degrees at the drag strip. To me, it was worth it because I can race, keep temps under the redline, and I paid a total of $200 for an intercooler to drop EGT's 100 degrees. Think about how much an AFE Stage II costs, or how much a 4" exhaust system cost, in comparison to a 6.0L intercooler and the results you get in EGT's. I think I got a heck of a deal. Now if I bought a Spearco or DIIC, I would have spent an additional $1000 over what I paid for my current I/C, and would have at the most seen another 50 -100 degree drop in temps with my current mods. I just couldn't quite justify spending that much more money when my EGT's are already well in the safe zone. I do plan to keep my stock injectors for some time to come too.
But like I said before, if you plan on larger injectors, then you'll need something bigger than the 6.0L I/C to keep up. It's all relative, and your intercooler should match your application. Just like matching a turbo with your injectors. A 6.0L I/C is a good middle of the road upgrade, and cheap to do.
