turn it up
Old Sep 12, 2007 | 07:41 PM
7.3stacked's Avatar
7.3stacked
turn it up
i was wondering if anyone new how to turn up the pump on a 7.3l non turbo?
Old Sep 12, 2007 | 07:47 PM
7.3stacked's Avatar
7.3stacked
"fuel pump"
Old Sep 12, 2007 | 08:24 PM
bigbubba87's Avatar
bigbubba87
prolly the injector pump Dave S or someone should have the link on how to do it
Old Sep 12, 2007 | 09:37 PM
KJLYPW's Avatar
KJLYPW
http://www.members.shaw.ca/k2pilot/I...%20article.htm
This is what you are looking for, but make sure you have opened up you air in and exhaust out so you don't over heat your pistons, you need to have a pyrometer to ensure you keep temps at a safe level if you are going to add more fuel to a non turb charged engine.
Old Sep 12, 2007 | 11:23 PM
7.3stacked's Avatar
7.3stacked
yea i have opend up my exhaust quite a bit i have 5 inch stacks on it with 3.5inch exhaust and i took the soup bowl out of the air cleaner lid i dunno if that does much but if you guys can let me in on some other lil tune up tricks that would be awsome and thanx alot for the advice i will probably go do the tommorow and i will get a pyro too i lolve guages thanx again
Old Sep 19, 2007 | 07:44 PM
7.3stacked's Avatar
7.3stacked
does turning up the pump realy make more power? i seen some post's on hear that said it does and ia hev talked to guys around town and said it does but i talked to the guy who is gunna turn it up for me and he said it doesn't realy make a difference
Old Sep 19, 2007 | 08:42 PM
redneckaggie2008's Avatar
redneckaggie2008
To tell you the truth I have my 7.3 cranked up a bit, and I can really tell a difference in pulling power. As far as how fast it runs I really haven't seen a difference. The engine doesn't lug as easy as it used to. A high flow air system is what i'm working on right now. Yes it does help.
Old Sep 20, 2007 | 12:20 PM
7.3stacked's Avatar
7.3stacked
ok awsome i am looking for pulling power anyways i go camping alot and have a dirtbike and lil 17 foot travel trailer i pull so that is cool thanks
Old Sep 20, 2007 | 02:43 PM
David85's Avatar
David85
A simple way to describe the effect is to have more space under the accellerator. The truck is going to feel much more responcive of idle, since more fuel will get dumped in sooner in the throttle range and WOT will have even more fuel going into the engine.
The catch is, that the engine will have a hard time burning all the extra fuel, so if you overfuel if, you will get lots of black smoke, and high EGTs, which is why you have to be carefull.
Fuel economy will be affcted, especially if you like to use the extra power.
Old Sep 20, 2007 | 04:13 PM
wh336fire's Avatar
wh336fire
Turn up the fuel just a tad , and advance the ip timing a little and you should notice a difference . A ram air intake setup would also be a good idea . I'm also kind of fond of my headers .
Old Sep 20, 2007 | 05:21 PM
gumboluvr's Avatar
gumboluvr
Maybe I missed it, but are you getting black smoke now? If so how much and when? I would guess not, but if you are already blowin smoke, you will just burn more fuel without much affect.
Old Sep 21, 2007 | 04:13 AM
somedude's Avatar
somedude
Smile
I agree i tryed everything 3.5 inch exhaust(this made the most power),all kinds of timing(i have the tools), ramair,turn up fuel(makes thick black smoke) finnally got a turbo, awesome!!!!
Old Sep 21, 2007 | 09:46 AM
redneckaggie2008
where did you get the ram air? Fabbed up yourself or can you get a kit for these trucks?
Old Sep 21, 2007 | 12:08 PM
wh336fire's Avatar
wh336fire
Yes , self fabbed . Dave has a good pic of his .
Old Sep 23, 2007 | 04:24 PM
7.3stacked's Avatar
7.3stacked
yea so i got the pump turned and man its awsome i pulls up hills way better thats what i noticed the most anyways and i puffs black but not huge cloud its just perfect anyways guys thanks for all the input and stuff
