valve relieves
Old Sep 12, 2007 | 03:00 PM
hollenjoe's Avatar
hollenjoe
valve relieves
will 0 deck flat top pistons with out valve relief in a 400 crash into the valves ?? how much valve realese wwould it need?
Old Sep 12, 2007 | 08:12 PM
danlee's Avatar
danlee
Zero deck pistons made for a 400 have valve relief built-in. It is 2 or 3 cc. You don't have to worry about valves hitting the piston unless you have extremely high lift.
Old Sep 14, 2007 | 02:09 PM
hollenjoe's Avatar
hollenjoe
hmm thisismy real situation, ive got stock heads milled by .020, and i milled 351m pistons to get 0 deck height on a 400, Im thinking valves will smash into them, will it happen ?
Old Sep 14, 2007 | 02:28 PM
danlee's Avatar
danlee
Standard flattop pistons have valve relief built in, but since you milled it off you will have to check.
The way to check is to assemble the motor with the cam installed and mount one head and install the valve train, after you put some putty on the top of at least one piston. Then rotate the motor through at least two complete rotations. Take the head off and look for a dent in the putty. The thickness of the putty that is left will tell you how much clearance there is.
There is a certain putty that is used for this, and there is a minimum clearance that you need to allow for dynamic and temperature effects.
If you do not have enough clearance, you will need reliefs cut with a fly cutter on every piston.
A good automotive machinist can tell you what material you need and what the minimum clearance should be.
Old Sep 14, 2007 | 02:35 PM
hollenjoe's Avatar
hollenjoe
thankss a lot
captntim
Jun 3, 2006 02:18 PM
mathelm
1983 - 2012 Ranger & B-Series
Jan 14, 2003 04:07 PM
odie780
Apr 18, 2002 03:40 AM
perrymb
Oct 12, 2001 03:08 PM
hood
Sep 12, 2001 01:56 PM
