Sponsored by: Real Truck
Automatic Climate control, always on A\C
Old Sep 12, 2007 | 11:34 AM
Homeslice's Avatar
Homeslice
I noticed the other morning when it was in the 40's, I set my climate control for auto at 72 degrees and it still had the a/c lit on the display. I shut it off manually then it was fine. If I hit auto again, it kicked the a/c on. Does it measure the amount of moisture in the air or just temp? Is it normal to operate like that?
Old Sep 12, 2007 | 12:06 PM
Ikes_Fseries's Avatar
Ikes_Fseries
My 05 F250 does the same thing. Manually can adjust to anything but if you hit auto the AC comes on.
Old Sep 12, 2007 | 12:12 PM
johnnysF350's Avatar
johnnysF350
It is normal operation of the system. Even the manual climate control operates the A/C in all but one or two positions. A/C is used to control the amount of humidity in the air to prevent windows from fogging up and will normally cycle on if the outside temp is above 32 or so.
Old Sep 12, 2007 | 12:14 PM
walrus's Avatar
walrus
My 06 does the same thing. In Auto mode the A/C is always on. I suspect it's "controlling the climate" including humidity and therefore window fog. Blowing dryer air into the cabin.
Old Sep 12, 2007 | 02:26 PM
Homeslice's Avatar
Homeslice
Good to know. Thanks!
azchris
6.7L Power Stroke Diesel
13
May 7, 2015 06:22 AM
nikvil
Dec 21, 2014 09:47 AM
action_deez
Nov 14, 2014 07:08 PM
bakon
2009 - 2014 F150
Jul 30, 2014 02:16 PM
chaneyb
Jun 21, 2005 03:42 PM
