How to remove A/C vents without breaking?
Old Sep 12, 2007 | 11:31 AM
77red4x4's Avatar
77red4x4
I found some replacement A/C vents for my 77 at a junkyard and need to know the best way to remove them without breaking them. I can feel the tabs on the sides so I know how they are mounted, just can't get them out without breaking the tabs.
I really only need the swivel part of the vent but I didn't want to destroy it trying to only remove it.
Any advice would be appreciated.
Old Sep 12, 2007 | 02:27 PM
Mil1ion's Avatar
Mil1ion
Use a thin blade or ice pick through the louvers to try away the upper and lower tabs to allow the pivots to clear the housing..then pull the louver assembly out the register housing
Old Sep 12, 2007 | 03:11 PM
MikeWire's Avatar
MikeWire
x2
Also, I would use the blade/pick on the lower pivot, then work it out of the housing (it won't want to come out but it will) and you should get it out. Do it while it is still warm out, because they get very brittle in the cold.
I just removed all the louvres out of my 75 to clean them and this is how I did it. Just be careful and you won't break any.
Old Sep 12, 2007 | 03:37 PM
77red4x4's Avatar
77red4x4
I got it. Thanks for the tips. What's the best way to get the louver and housing out for future reference?
I only got one of the vents cause that's all I needed. Should I go back and get the rest? Usually don't find all the vents in a truck intact!
Old Sep 12, 2007 | 07:54 PM
77red4x4's Avatar
77red4x4
I went back and got the driver's side vent and one of the center vents for safe keeping. Also scored an ignition module (with the blue grommet), two bumper bolts, a screw for my washer reservior, and 6 brand new fishing flies--all for $10.
It's crazy how much personal stuff can be found in junkers.
Old Sep 12, 2007 | 11:02 PM
MikeWire's Avatar
MikeWire
Nice - always good to have spare parts!
nothercrash
19
Apr 27, 2022 07:46 PM
ag-ford-4x4
Oct 21, 2010 07:12 PM
02xlt3.0
1983 - 2012 Ranger & B-Series
Jul 2, 2009 11:56 PM
390unibody
2004 - 2008 F150
May 28, 2008 01:12 PM
Bronco79
Nov 16, 2001 12:44 PM
