starting problem
Old Sep 11, 2007 | 11:46 PM
palefoot's Avatar
palefoot
Question starting problem
I have a 1995 F-150 300 EFI. Recently I have had to use the accelerator to start the engine. I don't believe this is normal and was hoping for a few hints.
Thanks for hearing me out!
Old Sep 11, 2007 | 11:55 PM
radialarm's Avatar
radialarm
Well. You ain't said much yet. To start when was the last time you tuned it up, and are you getting any codes. We need more info, it might seem obvious to you but we ain't there.
Old Sep 12, 2007 | 12:03 AM
palefoot's Avatar
palefoot
It has been a while (3 years) since I tuned it up (spark plugs). I don't seem to be getting any codes ( I don't have a code checker for this old of model). No check engine light. Normally it would start without touching the accelerator per instructions from the manual. Now, aftering sitting a bit, one has to use the accelerator.
Old Sep 12, 2007 | 12:21 AM
radialarm's Avatar
radialarm
My 95 has to be tuned up about every 6 mos.(plugs) major tune up every year(plugs,plug wires,cap, rotor, filters, etc.). My plug gaps open up over a 6 mo. period, and it starts to run bad. I run a good injector cleaner about once a month. I put about 500m a week on mine. Also just because there is no CIL doesn't mean there's no codes. Autozone will check it for nothing, better safe than sorry.
Old Sep 12, 2007 | 12:28 AM
palefoot's Avatar
palefoot
Heavy! I have noticed the plug gap opening up before and had forgotten about it. Thanks for a place to start! Apparently it IS tune-up time. I looked but did not see.
I may be slow, but I'm sloppy.
Old Sep 12, 2007 | 12:33 AM
radialarm's Avatar
radialarm
Be sure to use dielectric grease on both ends of your plug wires it helps keep water out, also use it inside your distributor cap on the terminals and rotor contacts. Welcome to FTE. You can learn a lot here.
Old Sep 12, 2007 | 12:44 AM
palefoot's Avatar
palefoot
In my case, the more I know, the less I know. Meaning, that as my knowledge increases, the more things I realize I know nothing about!
Thanks for your patience. FTE has surpassed my expectations.
perryg114
Modular V10 (6.8l)
Feb 1, 2015 09:01 AM
ssnbdr75
Oct 13, 2011 06:33 AM
jimbomac22
Sep 28, 2010 08:38 AM
whadeen
New Member Introductions
Oct 8, 2008 09:22 PM
hmcgary
Nov 19, 2007 11:48 PM
