brakes fading
Old Apr 6, 2007 | 11:56 PM
qwik88's Avatar
qwik88
brakes fading
hi i have a 95 f350 psd and my pedal is fading to the floor if i hold pressure on them. i replaced the master cyl and ive done rear brake wheel cyl there are no visual leaks the truck sat with the res cover off for a few weeks i am wondering what could cause this problem? im thinking possible flex lines being bad
or a caliper being bad
but i dont want to throw 150 bucks down the drain if its not the calipers
thanks in advance
dan
Old Apr 7, 2007 | 07:04 AM
Lazy K's Avatar
Lazy K
Coukd be a faulty master cylinder. However I had the same problem with my `87 F250 and it turned out to be a faulty RABS valve unit. Unless your calipers are leaking it is unlikely to be them. There have been problems with flex hoses swelling under pressure but I would think it unlikely too. Are you sure you have no fluid leaks?
Old Apr 7, 2007 | 08:51 AM
qwik88's Avatar
qwik88
100percent positive theres no leaks
Old Apr 7, 2007 | 09:19 AM
Bruce R Leech's Avatar
Bruce R Leech
did you bleed the equalizer valve?
Old Apr 7, 2007 | 05:24 PM
qwik88's Avatar
qwik88
is the equalizer valve what looks like a metering valve??? if so yes we did
Old Apr 7, 2007 | 05:32 PM
Bruce R Leech
some times there is an air bubble that is just hard to get out . a couple of weeks ago I had a truck that I bled 2 pints before I got it.
Old Apr 7, 2007 | 05:34 PM
qwik88's Avatar
qwik88
we used a full 12 ounch bottle then like a quarter of a big thing that i had at the shop we bled each wheel atleast 15 times
Old Apr 7, 2007 | 05:41 PM
Bruce R Leech
are you using the dot 3
Old Apr 7, 2007 | 05:42 PM
qwik88's Avatar
qwik88
yes its dot 3
Old Apr 7, 2007 | 06:01 PM
Bruce R Leech
I think your next move should be to either replace or rebuild the master cylinder. it sounds like you have done every thing else right.
Old Apr 7, 2007 | 06:02 PM
Bruce R Leech
dont forget to bench bleed it before installing it
Old Apr 7, 2007 | 09:23 PM
qwik88's Avatar
qwik88
Old Sep 11, 2007 | 07:32 PM
ibleedfordblue's Avatar
ibleedfordblue
So What Is The End Result??????????
Old Sep 11, 2007 | 11:14 PM
radialarm's Avatar
radialarm
Ibleedfordblue, I guess he's another one of those guys that just use us for our knowledge, and only come back when they need more. It's a tough job,but somebody has to do it. hang in there man.
Old Sep 12, 2007 | 05:02 AM
StealthWyvern's Avatar
StealthWyvern
wow talk about bumping an old post. (Iknow it could be older but still)
