Grrrrrrrrrr
Old Sep 11, 2007 | 11:40 PM
smithc185's Avatar
smithc185
Grrrrrrrrrr
I SWEAR THE NEXT TENSIONER I HAVE TO REPLACE I WILL TAKE IT OUT AND THROW IT THROUGH THE FRONT WINDOW AT THE FORD DEALERSHIP. I HAVE REPLACED 4 TENSIONERS IN THE PAST 3 years. granted this was on diff trucks but all were mazda with the ford 3.0. I just dont get why these tensioners wear out so fast. i can put these things in, in my sleep
Old Sep 12, 2007 | 06:29 AM
wendell borror's Avatar
wendell borror
I would say it's not the part, but the mechanic if it was the same truck, so your off the hook ha ha.
Old Sep 12, 2007 | 09:59 AM
Bear River's Avatar
Bear River
Former ******
Well, i would suspect that the pulley is getting contaminated with oil or antifreeze which allows dirt and friction inside the bearings.
Old Sep 12, 2007 | 10:33 AM
projectnitemare's Avatar
projectnitemare
If they were on different trucks, not much you can do. I just replaced one on my friends 3.0 a few weeks ago. Upon closer inspection the seals were eaten and the bearings were dry.
Matt
Old Sep 12, 2007 | 03:38 PM
smithc185's Avatar
smithc185
I just thinks a factory flaw. I have a buddy that is having the same issue he is on his way over rite now so i can change his. Poor design.
Old Sep 12, 2007 | 04:12 PM
rkymtnman30's Avatar
rkymtnman30
Humm, I rarely see the Tensioner go bad on those 3.0L it is usually the danged idler pully I see a lot of I bet I have done 100 of them and only about 10 tensioners
Old Sep 12, 2007 | 10:40 PM
smithc185's Avatar
smithc185
Well i was thinking it could be the idler pulley on my truck. was making no since after i put a new belt on and less then 2k later it started swuealing again. no fluid leaks the belt is dry.
Old Sep 13, 2007 | 12:25 AM
rkymtnman30
I would check it first for sure!!!
Old Sep 13, 2007 | 08:40 AM
fordboy_52's Avatar
fordboy_52
um, chances are your pullies are off and it is riding to the back or front of the idler and this causes the bearings to go bad. i fixed mine and ive been fine for a while now
Matt
Old Sep 13, 2007 | 12:41 PM
crapmechanic's Avatar
crapmechanic
i have a 2003 3.0L and have replaced the idler and tensioner 3 times already do to the damn squeeking. I have seen this a lot in the shop i work at. Seems pretty common, and btw mine started at 3k miles the first time.
Old Sep 13, 2007 | 04:38 PM
smithc185's Avatar
smithc185
well i replaced the idler pulley and the tensioner and put a new belt on it. we will see.
