Dealer Deisel Diag. HELP!!!
Just got the truck back from the stealership. Diaged. Said code pulled was P2291. Low ICP pressure. Between 134 and 155. Alredy replaced ICP and CPS sensors. Truck still don't wana start. Bad ICP do ya think? Or, bad IPR? Dealer recommended replace IPR and HPOP to fix. $1500.00 WTF?? What say YOU? Truck is 2002 F250 PSD w/ 175,000 miles. 6637 filter and muffler delete. No other mods. Never driven hard. Truck has been driven to Clali, Texas, Oklahoma several times w/ no probs. Now it don't wanna start. Cranks good though...
Anyone familiar with this code? "Said code pulled was P2291. Low ICP pressure. Between 134 and 155."
I don't suppose any yall live in the Phoenix/Metro areas? I could always use a little guidance under the hood...
Might be worth a try.
Let me know if you want me to get you info on trouble shooting instructions from the manual on the ICP.
Hope I'm not wasting my time trying to help a squid out of water.
Why don't they just come out with one master code that says "take it to a ford dealer so we can overcharge you"?
Here you go...we typed over each other
Yeah on the "take it to a ford dealer code..." lmao
Just got home..
I have alredy purchased and installed new CPS and ICP sensors. No luck. Still won't start. The dealer is saying HPOP and IPR but, when I asked em if they tested the IPR separate to see if it was bad they said no.
So with a new ICP sensor and a bad IPR, I'm wondering if I will get that code and their computer will show low ICP pressure. The ICP could be good but if the IPR in the HPOP is bad then it would not have proper pressure and throw that code right?
Or am I way off here?
BTW nlemerise your link didn't go through for me... Sorry
Just a list of trouble codes, no trouble shooting help..... But thats what we're for.
Possible Causes:
• Injection control pressure system leak
• Oil reservoir level low
• IPR failure
• Faulty high pressure pump
• Injector O-ring leaking
Injection Control Pressure Leak Test
Removing the ICP sensor and inspecting the level in the oil rail will determine if oil is being supplied to the rail. Removing the inspection plug in the top of the reservoir will help determine if the reservoir is full. A reservoir that drains back after the engine has not been operated for a long period of time can cause a hard start condition. If reservoir empties after filling, verify it is being supplied oil from the low pressure oiling system.
Right Cylinder Head Check
Remove the high pressure hose from the right cylinder head using Quick Disconnect Tool 303-625, and cover the fitting on the cylinder head with the appropriate cap from the Fuel/Oil/Turbo Protector Cap Set T94T-9395-AH. Install the plug from the Oil High Pressure Leakage Test Adapter Set 303-S626 into the high pressure hose to block it off. Crank the engine and monitor the ICP PID. If the ICP Adapter Cable D94T-50-A is connected to the ICP sensor, connect a digital multimeter between signal return and ICP signal wires on the adapter cable. Crank the engine and monitor the signal. The digital multimeter should read 1 to 4 volts.
CAUTION: The engine may start!
If the engine starts or if injection control pressure is now within specification, the injection control pressure leak has been isolated to the right cylinder head. Inspect the fuel to see if oil is in the fuel. If no oil is present in the fuel, remove the valve cover, crank the engine and inspect the injector body and injector bore area for leakage.
CAUTION: Oil is under high pressure!
Left Cylinder Head Check
Remove the cap and plug, then reinstall the high pressure hose to the right cylinder head. Remove the high pressure hose from the left cylinder head using Quick Disconnect Tool 303-625, and cover the fitting on the cylinder head with the appropriate cap from the Fuel/Oil/Turbo Protector Cap Set T94T-9395-AH. Install the ICP adapter from the Oil High Pressure Leakage Test Adapter Set 303-S626 into the high pressure hose. Remove the ICP sensor and install the sensor in the end of the ICP adapter. Connect the ICP/EBP Adapter Cable D94T-50-A to the ICP sensor. Connect a digital multimeter between the signal return and ICP signal wires of the adapter cable. Crank the engine and monitor the signal. The digital multimeter should read 1 to 4 volts.
If the engine starts or if injection control pressure is now within specification, the injection control pressure leak has been isolated to the left cylinder head.
IPR and High-Pressure Pump Test
If injection control pressure is still low after ruling out both cylinder heads as the source of injection control pressure leakage, perform the following steps to isolate the cause. Leave the ICP sensor and ICP adapter connected to the left high-pressure hose. Remove the high-pressure hose from the right cylinder head and cover the fitting on the cylinder head with the appropriate cap from the Fuel/Oil/Turbo Protector Cap Set T94T-9395-AH. Install the plug from the Oil High Pressure Leakage Test Adapter Set 303-S626 into the high-pressure hose to block it off. With the high-pressure pump effectively deadheaded, crank the engine and monitor the signal. If injection control pressure is not within specification, replace the Injection Pressure Regulator (IPR) with a known good IPR and retest. If a low pressure condition still exists, the problem is most likely with the high-pressure pump or the high-pressure pump drive gear.
for the bad link (I left a space at the end of the url)...try this:
