where's the tach
Old Sep 11, 2007 | 05:10 PM
91 f350 dually's Avatar
91 f350 dually
where's the tach
I have 2 problems with my 91 f350 diesel. The speedometer just quite and the tach has' t worked since I bought it. I need to know how hard is it to change the speedo gear if that is the problem I think I can handle it if it is just the cable but I know my luck. I also need to know where the tach sensor is on this one. It is the interational 7.3 diesel with manual tranny. thanks todd
Old Sep 11, 2007 | 05:11 PM
greythorn3's Avatar
greythorn3
on my 86 it on the front cover by the oil fill tube.. tack sensor
Ray
Old Sep 11, 2007 | 05:14 PM
91 f350 dually
I have no wires to the cover or any sensor on the timing cover. todd
Old Sep 11, 2007 | 09:44 PM
catfish101's Avatar
catfish101
Look on the right side of the injection pump drive gear cover on the top edge. Is there any thing there?
Old Sep 11, 2007 | 10:21 PM
David85's Avatar
David85
The engines were avalable with or without the tach sensor on the IP drive gear housing.
Its possible that some one may have swapped the cluster from another truck that did have a tach setup, or maybe an engine form one that didn't.
1991 should have a cable driven speedo, so its all mechanical. Check both ends of the speedo cable and see if its still in one piece or if its just poped out at one end.
Old Sep 12, 2007 | 08:21 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Old Sep 12, 2007 | 01:36 PM
91 f350 dually
Thanks guys, I must have a motor change as I find the the connector on the wire harness but no place for sensor. Can I change covers with one that has sensor , but probally I don't have pickup on the ip pump chain or gear right. oh well who needs a tach thanks again Todd
Old Sep 12, 2007 | 06:57 PM
David85's Avatar
David85
Actually, I think the sensor uses the IP gear as the magnetic pickup, so all you would need is to swap the gear housing and buy (get) a new sensor.
Old Sep 13, 2007 | 09:33 AM
Dave Sponaugle
You can swap the drive gear housing.
But do be aware that you need to remove the IP first.
Then remove the housing.
When you remove the housing, be carefull that you do not unmesh the IP drive gear from the cam drive gear.
If the gears are seperated, you could have issues getting it back in time since the timing marks are not visible without removing the water pump and the timing gear cover plate, which is a lot more work.
Old Oct 4, 2007 | 04:34 PM
KIKO_FIEBRE's Avatar
KIKO_FIEBRE
Talking Tach Sensor For 1993
HI,THERE.
I OWNED A 1993 FORD F350 DIESEL "NON TURBO"
I'M LOOKING TO BUY A NEW OR USED "TACH SENSOR"
ANY ADVISE?
THANKS,ANGEL
Old Oct 4, 2007 | 05:15 PM
brownieboy525's Avatar
brownieboy525
[QUOTE=KIKO_FIEBRE]HI,THERE.
ANY ADVISE?
THANKS,ANGEL
[/QUO
only the dealership sells the tach sensor new
Old Oct 4, 2007 | 09:57 PM
catfish101's Avatar
catfish101
Sensor is easy to locate. That is a standard " common" thread in the housing for the sensor and the sensor is a basic ac generating sensor. If you have a parts store for a bigtruck near you can pick up a VSS sensor that is threaded and use it. Screw it in till it touches then back it out 1/4 to 1/2 turn. Wire it up and go. You have other options if you can't find the OE sensor.
