Cleveland or Windsor
Old Sep 11, 2007 | 03:03 PM
CATFORD's Avatar
CATFORD
Sorry to ask a stupid question....but what 302 engine is in a 1977 F100....a Cleveland or a Windsor?
Also what Transmission did they come with....mine has a Column shift auto.
Cheers Rory!!!
Old Sep 11, 2007 | 03:13 PM
HemiEater's Avatar
HemiEater
A 302......
Old Sep 11, 2007 | 03:23 PM
CATFORD's Avatar
CATFORD
Hi Hemieater,
Well I'm only guessing its a 302 (4.9ltr) going off the carby as it is very small.....the car salesman said it was a 351....what size V8 did they come out in back in 1977?????
There is a couple of pic in my gallery labled CATFORDS 1977 F100....maybe that will help anyone....unfortunatley its not a great pic of the engine!!!
Old Sep 11, 2007 | 03:29 PM
HemiEater's Avatar
HemiEater
That's a 351M by the looks of it
Old Sep 11, 2007 | 08:43 PM
baddad457's Avatar
baddad457
If it's a 351M, it's got a C-6 behind it. Could also be a 400, only way to tell is the ID tag on the valve cover (if it's there and the motor hasn't been molested since new)
Old Sep 11, 2007 | 09:49 PM
havi's Avatar
havi
I'll have the Roast Duck
It's an Australian model. Count the valve cover bolts, and post back.
Old Sep 11, 2007 | 10:10 PM
baddad457's Avatar
baddad457
I just looked, thats more'n likely a 351C, definately ain't a Windsor and now that I see you're "down under" I doubt it's either a 351M or 400. Transmission? That I can't tell you, other than you'll have one of these three: C-4, FMX or C-6 if it's an automatic. The C-4 has a removeable bellhousing, with the bell bolts inside the bell. The FMX also has a removeable bell, looks like a manual with the bell bolts outside, and a cast iron main case, C-4 case is aluminum The C-6 has a one piece bell and main case, all aluminum.
Old Sep 11, 2007 | 11:49 PM
CATFORD's Avatar
CATFORD
Thanks for the feedback guys....I ve decided to go and pick it up Tomorrow now instead of Friday.....so i will look at all the things you have pointed out.
Thanks again your help is greatly appriated!
Old Sep 12, 2007 | 04:44 AM
CATFORD's Avatar
CATFORD
Here are the Vin and Engine numbers are...if they help.....
VIN # ALIJST46240K
ENG # ALIJPA28616K
Old Sep 12, 2007 | 04:52 AM
HemiEater's Avatar
HemiEater
any numbers on a tag stuck to the valve cover.
Old Sep 12, 2007 | 03:05 PM
CATFORD's Avatar
CATFORD
Pick it up today will check first thing....i only got the above numbers from the guy selling it!!!!
Old Sep 13, 2007 | 01:30 PM
HemiEater's Avatar
HemiEater
what is it?
Old Sep 13, 2007 | 02:35 PM
51dueller's Avatar
51dueller
I thought they were all clevelands down under? They had a 302C which lots of 400 guys use the cylinder heads.
Old Sep 14, 2007 | 04:02 PM
alxsnmr's Avatar
alxsnmr
Aus had a destroked 351c that was the 302c. It looks like the M because the M block was based off the 351c. Only way to tell what it is is to see how long the stroke is on the motor. If the engine label says 302 then it probably is the 302c.
Old Sep 14, 2007 | 04:39 PM
CATFORD's Avatar
CATFORD
Thanks mate...doing the plugs today so I will give the stroke a measure then.....I appriate all the help!!!
