427 Heads
Old Sep 16, 2002 | 10:29 PM
wickman's Avatar
wickman
427 Heads
Cobra 427 fe mr heads,what are they worth? what does the mr stand for?
Wick
Old Sep 16, 2002 | 11:14 PM
dinosaurfan's Avatar
dinosaurfan
427 Heads
MontanaWick, 427 MR heads, if you had the bare castings, used, would probably sell for about 350-400$ each. The valves are bigger than in other FE cylinder heads and cost more than average, lots more. The 427 heads will only work on the 427s bigger 4.23 bore because the big valves hit the cylinder walls on the smaller bores. I think they will work on a .060 over 428, but you have to notch the bores. If you should happen to see some of them, the casting # is C5AE-F. The Medium Riser (as opposed to a high riser or low riser) gets its name from the matching manifold that was supposed to be used with the heads. DF
Old Sep 17, 2002 | 03:45 AM
Blown65's Avatar
Blown65
427 Heads
mjl351w
Sep 14, 2014 02:54 PM
Mr. Fixit
Mar 7, 2006 04:35 PM
jbulson
Jan 10, 2003 03:52 PM
anotherF150
43
Nov 30, 2002 07:25 AM
FE427TP
Jul 7, 2001 03:01 PM
