STOCK 390 ENGINE PARTS
Old May 27, 2002 | 11:15 AM
ruthless's Avatar
ruthless
I will have a variety of parts left over that will never return to that motor. What do you suggest I do with them they are:
The two bbl manifold with carb, stock valve covers, stock air cleaner and exhaust manifolds with associated heat sheet metal, cam. Thats about it.
Old May 27, 2002 | 11:35 AM
karlsd's Avatar
karlsd
Lots of guys have the same issue. Me, for instance. I have almost exactly the same stuff left over that you do. I also have a 390 crankshaft and rods, but I'm going to save those for the 406 or 427 I plan to build some day.
Frankly, I suspect that I will end up scrapping most of that stuff. Those parts are plentiful and there is no demand for them, so you can't even give them away, let alone sell them.
Old May 27, 2002 | 02:49 PM
ruthless's Avatar
ruthless
, Okay then, I will give them the old heave-ho. I am not a pack-rat.
Old May 27, 2002 | 02:58 PM
FE427TP's Avatar
FE427TP
if the exhaust manifolds aren't cracked save them you can probably get about $75 for them from someone who has a cracked manifold and needs to replace it
Old Sep 17, 2002 | 03:20 PM
1974fordtruck's Avatar
1974fordtruck
Before you chunk the carb, what model is it? I am in need of a stock one. I think mine is causing my some sputter but don't re ally want to buy a new one. Thanks. Billy
Old Sep 17, 2002 | 03:25 PM
rebocardo's Avatar
rebocardo
KO1960
Sep 17, 2012 12:55 AM
51PanelMan
75
Apr 15, 2012 12:05 AM
Joe_C
Jan 18, 2011 07:40 PM
azwafree
Feb 18, 2006 12:32 AM
