Modular V10 (6.8l)
Someone please help!!
Old Sep 11, 2007 | 01:08 AM
Mydirtytruck's Avatar
Mydirtytruck
Ok guys, i have an 01 F250 with the mighty v10. I drove it to the Ford dealership just to look around, and i got back into the truck to leave, turned the key, and nothing. I figured my battery died somehow. I tried to get a jump from another car, and from a jumpbox, no luck. bought a new battery, and nothing. i touched a screwdriver from the pos to the neg terminal on the solenoid to see if i could get the starter to turn over, no luck. took the starter to discount auto parts to be tested and it tested fine. im kind of out of ideas, ive checked all my fuses, both under the hood and under the dash. Someone mentioned that it could be an inline fuse somewhere, but i just figured id check here for suggestions. when i connect the battery, there is power to the truck, but as soon as i put the key in the ignition and turn it, power shuts off, not even enough power to turn the radio on or put the windows down. Any suggestions will be appreciated!!!
Old Sep 11, 2007 | 03:08 AM
Zip's Avatar
Zip
I don't know, battery cables maybe.
Old Sep 11, 2007 | 08:20 AM
Fredvon4's Avatar
Fredvon4
Corroded grounds is my best guess
Old Sep 11, 2007 | 12:09 PM
FortyFords's Avatar
FortyFords
To Tell the truth ,you have pissed off your truck! It feels let down that you would even think of getting a new truck!LOL!!!!!
Chk the neutral safety sw ,wiggle the shifter while turning the key
chk wires on trany switch.
all above have been good suggestions also
Rich
Old Sep 11, 2007 | 01:59 PM
meanv10's Avatar
meanv10
Denfinatly check the ground had the same problem on my F150.
Old Sep 11, 2007 | 02:13 PM
i eat hybrids's Avatar
i eat hybrids
Its not starting because it wants to stay at the dealership and get an oil change Hope u fix the problem
Old Sep 11, 2007 | 02:14 PM
lwfox002's Avatar
lwfox002
Good that you were in a Ford dealer lot. Truck may have just burned up if you were in a "other" lot.Sounds like a ground connection to me also.
Old Sep 11, 2007 | 02:18 PM
greythorn3's Avatar
greythorn3
http://img443.imageshack.us/img443/7...sonhahaai1.jpg - EDITTED BY MODERATOR krewat
Old Sep 11, 2007 | 02:50 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by greythorn3
And your point is?
Old Sep 11, 2007 | 03:02 PM
Carpainter29's Avatar
Carpainter29
Thats not really helpful, but i would say it sounds like a cable issue.
Old Sep 11, 2007 | 05:12 PM
Big Orn's Avatar
Big Orn
I agree with the cable and/or some other grounding point.
Those OEM clamps can crack sometimes and not be visibly bad. The connector bolt for the clamps can also get corroded and fail.
Hope you find the problem and fix it pronto!
And, welcome to FTE!
Old Sep 11, 2007 | 08:13 PM
Mydirtytruck
thanks for all the suggestions everyone! yeah, the pissed off truck was my first theory, but i wouldnt think it would hold a grudge this long....unless of course its a woman! anyway, i was gonna try the cable thing and maybe the selenoid tomorrow. Once again, thanks for all the suggestions!!
Old Sep 12, 2007 | 05:14 PM
krewat's Avatar
krewat
Let us know how it goes!
Old Sep 12, 2007 | 05:49 PM
meanv10's Avatar
meanv10
You must know my girlfreind.
Old Sep 12, 2007 | 06:22 PM
Mydirtytruck
this may sound goofy, but what oem clamps and bolt are you talkin about? im still not having any luck. today i changed out the ignition key lock cylinder, still no luck. when i was putting the stock one back in, i plugged it in but didnt have it bolted in yet, and i got power to the truck. the truck still didnt want to start, but at least i got power to the truck, ie, the radio came on, i could put windows up and down, all that good stuff. any new ideas?
