Modular V10 (6.8l)
Someone please help!!
Old Sep 12, 2007 | 06:45 PM
Fredvon4's Avatar
Fredvon4
On your alternator there is a wire over to the red+ side of the battery and a primary connector right there on the black - side is a clamp... from the negative - side there are several places where the battery is grounded to the fender, frame and motor.... if not you need a good solid ground to all three!
You problem is starting to sound like loose connectors or broken wires in the steering column
Old Sep 18, 2007 | 03:18 AM
afbrian13's Avatar
afbrian13
I would say the battery ground cable to the block needs replaced. Had the exact problem on my old bronco. If you ohm out the wire it prob. has very high resistance. Swap it out and i bet it will start.
Brian
Old Sep 18, 2007 | 11:13 AM
Mydirtytruck's Avatar
Mydirtytruck
i took the starter off and had it tested. The guy at the parts store said that it was good, but they could not test it under a load. Is there any way of testing the starter while its on the vehicle? i tried shorting out the selenoid, but dont get anything, which could be caused by the bad ground. i would just like to eliminate 1 thing at a time. Please keep the suggestions coming!!
Old Sep 18, 2007 | 12:13 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Use a pair of jumper cables, and connect the block to the (-) side of the battery - that'll ground the block and complete the circuit - after that, shorting the big terminals on the solenoid/relay on the fender, it should turn over or at least try to. If it doesn't, there's something wrong on the positive side. Or the battery is dead.
Old Sep 20, 2007 | 06:43 PM
Mydirtytruck
ok guys, the beast is fixed!! the problem was that the positive battery cable was so corroded that there was no power going to the starter. I replaced that cable and now everything is good. thanks for all the imput and suggestions!
Old Sep 20, 2007 | 09:05 PM
lwfox002's Avatar
lwfox002
Alright, glad you found the problem.
mcerchio
Jan 7, 2020 08:05 PM
Izera
1997 - 2003 F150
Aug 16, 2013 10:01 PM
jln_Wasabi
Electrical Systems/Wiring
Mar 3, 2004 10:36 PM
Beasty-Fella
1978 - 1996 Big Bronco
Nov 11, 2003 06:49 PM
Gwilkrrs
49
Mar 23, 2003 10:47 AM
