It lives
Old Sep 11, 2007 | 12:42 AM
eprn1n2's Avatar
eprn1n2
It lives
So after replacing my timing chain cover and harmonic balancer my 1990 250 5.8L EFI is now running though roughly. I'll change cap, rotor and plugs to start with. Is there anything else that would quiet this beast down? It feels like it is missing on a cylinder.
Old Sep 11, 2007 | 08:03 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
It's possible the timing marks were not lined up. Does it run rougher than it did before you changed the timing set? If there was alot of slack in the old timing set, you probably had to rotate the crank just a little to get the new set on. Could be that the cam is off 1 tooth in relation to the crank.
Old Sep 11, 2007 | 08:13 AM
eprn1n2's Avatar
eprn1n2
I don't think that's an issue as the timing chain was never removed so the timing didn't change. The origional issue was the harmonic balancer that came apart. My son drove it like that and the metal ring on the balancer broke through the timing chain cover.
Old Sep 11, 2007 | 09:29 AM
SteveBricks
FTE Emeritus
My bad. I read right through the word cover. Early, you know. Does that motor have a crank position sensor?
Old Sep 11, 2007 | 10:16 AM
eprn1n2's Avatar
eprn1n2
I'm not sure. Where is it located?
Old Sep 11, 2007 | 10:39 AM
Skandocious's Avatar
Skandocious
I don't believe we have a CPS in the gassers, I think thats a diesel thing.
Old Sep 11, 2007 | 10:42 AM
Skandocious
Theres a lot of things that could be causing this truck to run rough, so that's a tough call. If you have any clues as to when it started or other related symptoms then we can take it from there. I'd get that tune-up taken care of first thing, that might even fix the problem.
Old Sep 11, 2007 | 12:03 PM
pfogle's Avatar
pfogle
It runs rough, how old are the plugs, wires, cap rotor? What brand? Are they still dated the model year of the truck? Use only high quality parts, motorcraft wires, $30 gp sorensen (Advance Auto) or napa premium line (around the same price) cap and rotor. ONLY motorcraft COPPER plugs, the platinums do not work well with the older ignition systems. From there double check the firing order, and wire routing. I made the mistake of crossing two plug wires on my 302. It ran but had a dead cylinder. Found the problem, and swapped it back to where it should be and it smoothed out like glass.
Old Sep 11, 2007 | 01:10 PM
eprn1n2's Avatar
eprn1n2
the stuff on it now if not origional is very old. Thanks for the advise.
Old Sep 11, 2007 | 02:33 PM
eco's Avatar
eco
Any codes??? If not, and it still runs rough after replacing all the tune up parts, the only things I can think of to do next would be a compression test (matter of fact you should just do that when you take the old spark plugs out) and replace/clean/rebuild the fuel injectors...I would just replace with Ford parts but some like to cut costs.
Old Sep 11, 2007 | 05:24 PM
eprn1n2's Avatar
eprn1n2
Put in the cap, rotor,wires, and plugs. That has pretty much taken care of the rough running. One spark plug was burnt and one wire was melted through. Does the O2 sensor do much on this thing? If it does I should change that as well.
Old Sep 11, 2007 | 07:04 PM
eco's Avatar
eco
In closed loop, it does plenty.
02 Super Duty Guy
Oct 7, 2014 05:39 PM
Patrick714
May 30, 2014 05:23 AM
ford2go
User Gallery & Picture Display
Jun 24, 2008 06:24 PM
masterbeavis
Jun 21, 2002 12:19 AM
swirk
May 2, 2002 08:01 PM
