6 speed and shift points.
Old Sep 11, 2007 | 07:54 PM
pullinair's Avatar
pullinair
Originally Posted by Fat Diesel
I usually shift around 2700, but take it to 3200-3400 once or twice a day.
I second Fat. My psd gets cleaned out once or twice a day. On a bad day, like after I hear about bad news, she'll see that all day long. The truck takes it and asks for more.
Old Sep 11, 2007 | 08:01 PM
DCSpecial's Avatar
DCSpecial
My 2000 F-450 is a ZF-6 (only one, rest are autos....and I'm pretty much the only one who drives it). I normally shift in the 2200-3000 RPM range, all depends on traffic, and if I'm loaded heavy or not.
No way in hell I'll shift at 2000rpms when I come off the scales at 26,000lbs........I'm normally just under 2000rpms a lot of times as soon as release the clutch in the next gear.
The truck has 4.88 gears....so my RPMs get high quick, and I push higher rpms at speed.
Old Sep 11, 2007 | 08:07 PM
littledre1's Avatar
littledre1
Originally Posted by IDPisan
I used to shift at a rpm maximum of 2000. Then I got my 5" exhaust, got to hear my baby purrrrrrrr. 2500 to 2800 now .
In order to justify the lost fuel and shifting at a higher RPM I might have to get the 5" Cannon!
PMS is a cruel mistress.
Old Sep 11, 2007 | 08:34 PM
justblowin'smoke's Avatar
justblowin'smoke
5" stacks sound sweet right around 2000-2500 then when u let off to swift u get that great turbo sound
i shift mine at 2000-2500rpm but when i was driving it every day to work i only revved it to 2000-2200 to get better fuel economy
Old Sep 11, 2007 | 08:52 PM
F350-6's Avatar
F350-6
It depends on if your towing or driving empty. It depends on if your looking for better MPG's or better power. All of the above posts are correct. The one thing they forgot to mention is it also depends on which gear you are shifting in to (or down to). The RPM change is not constant between each gear.
ErrorS
1978 - 1996 Big Bronco
29
Jul 28, 2017 03:36 PM
Steven Valvana
Jun 10, 2016 04:03 AM
ford410
36
Apr 11, 2011 11:25 PM
psimon
17
Oct 1, 2010 02:29 PM
davzog
Modular V10 (6.8l)
21
May 29, 2006 09:40 PM
