Sponsored by: Auxito
97 f-150 fuel pump fuse prob.
Old Jul 1, 2002 | 06:50 AM
JVDALLAS1's Avatar
JVDALLAS1
I HAVE A 97 THAT KEEPS BLOWING THE 30 AMP FUSE UNDER THE HOOD.
THE PROBLEM JUST APPEARED AND NOW THE FUSE WILL BLOW UPON TURNING THE KEY ON. I HAVE TRIED A 40 AMP AS WELL AS A 50 AMP FUSE ALL TO NO AVAIL. WHEN IT FIRST HAPPENED, I WAS DRIVING ABOUT 30 MPH. I REPLACED THE FUSE AND IT LASTED ABOUT 4 BLOCKS. NOW IT WILL BLOW WHEN I TURN THE KEY. WHAT IS THE DEAL? IS THIS A COMMON PROBLEM OR JUST AN ISOLATED INCIDENT? ANY HELP WOULD BE APPRECIATED. OH, MY ENGINE IS A 4.2L AND AUTOMATIC TRANS.THE FUSE BLOWING IS THE ONE UNDER THE HOOD ON THE DRIVERS SIDE FENDER.
Old Jul 1, 2002 | 08:07 AM
Yellardawg's Avatar
Yellardawg
I'd be looking for a "Short" in the line that is blowing. If it continues to blow 30-40 and 50 amp fuses then something is wrong. Fuses are designed to blow so you don't burn up wiring and more expensive parts. Don't go up in amperage of a fuse, you lose protection.
YD
Old Jul 1, 2002 | 02:59 PM
Tom Gray's Avatar
Tom Gray
nick_ct_203
Jun 23, 2017 06:42 PM
gpineau
New Member Introductions
Jan 2, 2017 07:49 PM
mudguts
May 2, 2016 02:54 AM
Bubba Hines
Dec 19, 2015 09:06 PM
GreaseMonkey519
Dec 12, 2015 08:11 PM
