galaxy cross member?
Old Sep 9, 2007 | 12:05 PM
53f100owner's Avatar
53f100owner
Hey guys. it`s been a while since I posted. I had a deal for a 53 that fell through so I put the search on hold for a while. Anyway, I found a 55 with a galaxy cross member. I`ve never seen one with this cross member. Is this a common conversion? The price is good and looks to be in pretty decent shape but I was looking for a truck with a stock frame so I could install a MII set up. Thanks guys.
Old Sep 9, 2007 | 01:08 PM
Randy Jack's Avatar
Randy Jack
FF56 has done many Effies with full size Ford IFS. They ride very well and are generally more stout than an MII. If you consider that any aftermarket MII will cost thousands in parts alone, this may be a good find.
Old Sep 9, 2007 | 01:11 PM
53f100owner
Thanks for the info. good point about the MII set up. The guy is asking $1975 but i`m sure he will take less. He started at just over $3k a few months back.
Old Sep 9, 2007 | 02:23 PM
tacson's Avatar
tacson
My 55 has a Crown Vic front clip which the main difference is my steering box is out front of the crossmember where yours is behind. IF you don't buy the 53 would you send me some pictures. Sounds interesting.
Old Sep 9, 2007 | 02:26 PM
53f100owner
The 53 I was looking at is long gone. I was going to do a trade for a el camino I had but it never worked out.
So as far as fitting a engine onto the galaxy cross member, what are my options? It had a 390 before.
Old Sep 9, 2007 | 02:35 PM
tacson's Avatar
tacson
Depends on the year. Like a 68 came factory with either a 240,302,390, and 428. A 72 had 240,302,351W,351C/400, and 429. Now if you are willing to make motor mounts you can put any Fomoco engine in it. You would have problems although with the MOD motors because the steering box to exhaust manifold clearance would not be good at all. THanks DOnald
Old Sep 9, 2007 | 02:37 PM
53f100owner
Thanks Donald. I don`t know what year the crossmember is but I can ask him. I was thinking of using a EFI 5.0/AOD since this will be a driver.
Old Sep 9, 2007 | 02:42 PM
Fomoko1's Avatar
Fomoko1
The EFI 5.0/AOD should be a god fit.
Old Sep 9, 2007 | 02:53 PM
tacson's Avatar
tacson
Check out the pictures in my albums. 5.0EFI-AOD out of 88 Crown Vic. 17k since August 2003
