General Automotive Discussion
2002 taurus check engine light
Old Sep 9, 2007 | 08:59 AM
Ford-Trucker84537's Avatar
Ford-Trucker84537
i got a 02 taurus and the check engine light is on, the code is P1400, anyone know what this means, i got a haynes manual and it does not tell you what this code means
Old Sep 10, 2007 | 11:46 AM
Rockledge's Avatar
Rockledge
99% of the time a P1400 code is caused by a bad DPFE sensor. You should also check the wire harness for any breaks or kinks, and when you check and/or replace the DPFE, make sure the rubber hoses aren't clogged up with carbon, as well.
