differance between OBS and 99+
Old Sep 8, 2007 | 07:05 PM
93f1505.0L's Avatar
93f1505.0L
What are the main differances between the two (preformance wise).
The reason I ask is I have a 96 4x4 ext cab long bed 7.3 and my buddy jus got a 99 4x4 ext cab short bed. His is lifted on i think 35s and mine is stock on 285s. We raced and we were neck and neck untill his truck stoped spinning and hooked up and the he pulled away.(mine never spun) We both have the same basic stuff done programer, intake, and exhuast. I cant have him keep betting me.
The differances i know of are intercooler, 17* hpop, and IDM
Any thing esle?
Thanks
John
Old Sep 8, 2007 | 07:12 PM
MLCinNCTX's Avatar
MLCinNCTX
What gearing do each of you have?
Old Sep 8, 2007 | 07:13 PM
tjbeggs's Avatar
tjbeggs
bigger injectors, better tranny, different (not really better) turbo, higher HP stock. But the big thing is the bigger injectors that are supported by the IC, HPOP and IDM.
To beat him you need a set of stage 1 injectors, a TW or DP chip along with gauges it you don't already have them. Also with the bgger injectors you need to address your tranny or it will die a very short, hot painful death.
glasseater's Avatar
glasseater
injectors... that's the main thing
Old Sep 8, 2007 | 07:38 PM
Aireeek's Avatar
Aireeek
PCM also went to EEC-5
Old Sep 8, 2007 | 07:50 PM
c00nhunterjoe's Avatar
c00nhunterjoe
96-97's are all eec-v, and 95's are tto, some early's were oddballs
Old Sep 8, 2007 | 07:58 PM
Aireeek's Avatar
Aireeek
Really? I read somewhere they changed in 99. How much does a EEC-v cost? I actually grabed one off of he 2000 SD that I grabed the IDM from a couple of days ago.
Old Sep 8, 2007 | 08:04 PM
c00nhunterjoe
perhaps i should rephrase to avoid confusion, all powerstrokes are obdII, the universal connector under the dash makes it obdII compliant. the pcm from a 99 is no better than a pcm from a 97, they are not interchangable, the 99-ups are faster because of the injectors and hpop's and different turbos not the pcm's, the idm from a 99-up is better and is a direct swap, i think 02 and 03 are more volts then the 99-01
Old Sep 8, 2007 | 08:07 PM
Aireeek's Avatar
Aireeek
I know its not a direct swap due to the split shot injectors being ran by it, but could it be reflased to our years?
Old Sep 8, 2007 | 08:11 PM
c00nhunterjoe
if its reflashed then the whole point of the swap is defeated, i dont beleive it would work. the only way is if you got a blank pcm and manually programmed it using ford's AS BUILT data but even then all you would succesfully do is put a box from a superduty in your truck, not a superduty program, the sd program; if it even starts; would have an immediate check engine light due to the missing sensors on the obs trucks. again, there is no benefit from the sd pcm programming
Old Sep 8, 2007 | 08:18 PM
Aireeek's Avatar
Aireeek
In that case you will soon find it for sale on E-bay. I only paid 15 dollers for it and 15 for the IDM at the same time. I know they sell for several hundred dollers. If it could be reflashed to our years I would keep it as a backup.
Old Sep 8, 2007 | 08:38 PM
1997F-350's Avatar
1997F-350
keep the idm that will work in your truck.
Old Sep 8, 2007 | 08:43 PM
Aireeek's Avatar
Aireeek
Ya, thats why I was there in the first place. It was kind of funny, the IDM and the PCM were like the ONLY thing left of this truck. I dont think Ive ever seen a vehicle stripped as much as this one was. I just couldnt pass up the PCM as well.
Old Sep 8, 2007 | 09:29 PM
93f1505.0L's Avatar
93f1505.0L
Thats what i was planning on doing. Stage 1s, different chip, and im looking at putting an intercooler in out of an 01 7.3l, and i want to find a 17* hpop too. I know a tranny rebuild needs to be in the works too. Oh and once c00n gets the 22k figured out I might try that out too.
Not sure on the gears. The tag is off my truck and I dont know his either. Im pretty sure we both are 3.73 but im not sure.
Cant wait to smoke him
Old Sep 8, 2007 | 09:40 PM
c00nhunterjoe
94-97 trucks are either 3.55's or 4.10's, easiest way to tell, if you have stock tires on it at 60 mph with 3.55's you should be around 1800 rpm. with 4.10s at 60 mph you should be over 2000. that or read your door code....lol
i am stuck without the 22k, i dont want to bug my buddy for the ford scanner for a few days to let the whole new baby thing settle in. i need the ngs so i can get pid data and have active command over the solonoids to get a handle on what is happening
