Front drivetrain binding
Old Sep 8, 2007 | 12:04 PM
Len Hebb's Avatar
Len Hebb
Hi all,
I have a 2001 expedition with awd. When making slow turn either direction, going forwards or backwards, I get an intermittent binding coming from the front drivetrain. I have removed the front driveshaft and the problem went away. I have already replaced the ujoints in the drive shaft and that didn't help. Any thoughts or help would be appreciated.
Old Sep 8, 2007 | 06:22 PM
wrenchturner's Avatar
wrenchturner
is it awd?
When did you last do a fluid change in the differentials?
Old Sep 8, 2007 | 08:40 PM
Len Hebb's Avatar
Len Hebb
It is awd, and the fluids were changed by a drive train shop at 60k. I don't use the 4wd very often and this trouble has started within the last 6 months or so. The shop I am using now thought at first the problem was the rear differential clutches and replaced them. I pulled the front shaft after that and found the trouble gone.They will be looking into the Transfer case and front differential next. Are there clutches in the front differential also? I have read in some of these threads also that the electric motor on the transfer case also seems to cause od troubles
midas72
Dec 13, 2015 01:09 PM
racngrn
Oct 1, 2015 07:03 PM
86f250hd
Nov 25, 2014 03:29 PM
tyler.purrington
1978 - 1996 Big Bronco
Jan 17, 2014 02:09 PM
