Does one have to use the Ford grease to do the slip joint (driveline) or will Napa standard in the bucket Lithium grease work. Im sure either will do more than whats there now but i dont want to have any issues later from not using the ford stuff unless i have to THX
there is no replacement for the ford ptfe. i tried everything but the ford stuff in my f150 and nothing compared to ford's ptfe for how long it lasted. it's expensive stuff but worth every penny.
someone makes it for Ford. Just like BRP's fancy, expensive semi synthetic 2 stroke injector oil...that's made by Castrol and about 60% less if you buy the Castrol branded oil.
