Oil & Lubrication
U-Joint Grease
Old May 1, 2009 | 06:32 AM
Freaksh0w's Avatar
Freaksh0w
U-Joint Grease
What kind of grease do you guys use on your U-Joints? I have been using the Motorcraft black chassis lube on mine... and now someone said to never do that. Do I need to use another type? I grease everything under my truck about every 500 miles.
Old May 1, 2009 | 01:51 PM
cmlind's Avatar
cmlind
Any standard chassis grease or lithium based should be ok for u-joints. Especially on your schedule. May me more often than needed, but you will never have a stuck zerk at 500 mile intervals! Only problems you may have is too much grease. I don't like to pump too much in - it makes a mess and lots of dirt sticks to parts.
I use Mystik JT6 synthetic grease, but only so I can use one grease for the truck, tractor, and trailer bearings. I would use standard JT6 if it were only my truck. I grease the u-joints about every oil change. I think they could go longer, but I feel better getting a couple pumps in more often.
I think it is good to stay with the same grease rather than switching around in case one is not compatible, although I have switched and never had problems.
Old May 2, 2009 | 05:27 AM
bucci's Avatar
bucci
When you say standard chassis grease you mean a grease labeled as GC/LB right?
Old May 2, 2009 | 10:58 AM
Freaksh0w's Avatar
Freaksh0w
I mainly do it every 500 miles because I always get mud up under my truck from going out in the mud. I can't resist, lol. So, I go to a car wash and spray out the underside really good, then the next day before I drive, I usually grease everything.
I think this is the product I got: AutoZone.com | Lubricant/Grease | 14.1oz.(399.728g.)Ford,LincolnandMercuryVehiclesMu lti-PurposeGreaseTube
Valvoline Ford, Lincoln, Mercury Multi-Purpose Grease. I bought it around a year ago, so I can't remember. It was either this kind, or the specific chassis lube. I'm thinking it was this, now that I look at it. It says it's ok for UV joints. Thanks for the answers.
Old May 2, 2009 | 02:52 PM
Lazy K's Avatar
Lazy K
I use Mobilgrease MP and have never had any problems with it.
Old May 2, 2009 | 06:50 PM
pjwoolw's Avatar
pjwoolw
Redline synthetic CV-2.
Old May 4, 2009 | 11:34 AM
Dean88's Avatar
Dean88
Lucas Red N Tacky
Old Jun 17, 2009 | 09:02 AM
Kestas's Avatar
Kestas
The best grease for u-joints is Kluberplex BEM 34-132. It's a NLGI 1.5 calcium complex grease designed for micromotion applications, which is what the needle rollers in the u-joint do. It has excellent water washout resistance and is rated to run for 2000 hours at elevated temperatures. In the real world that would be around 100,000 miles.
Because it's a calcium complex, a complete changeout of the grease would be necessary to remove any lithium-based grease previously used.
Old Jun 19, 2009 | 08:08 PM
4x4 Bart's Avatar
4x4 Bart
Never use any grease with moly in needle bearings!
Old Aug 2, 2009 | 03:33 PM
master_mechanic's Avatar
master_mechanic
why not what will it do?? i use moly stuff in everything... i even use dow cornings gear oil additive in my axles.
Old Aug 2, 2009 | 07:47 PM
4x4 Bart's Avatar
4x4 Bart
It erodes needle bearings, like used in u-joints. At least one lube company has a formula that it claims is dual purpose moly but I won't use it. Moly is a dark hard gray powder that does not work well in fast moving, tight clearance applications. It needs room to move.
Automotive manufacturers recommend lithium for u-joints for this reason. I found out the hard way. I was a doing lots of off roading and greasing my u joints every week with moly. The needle bearings were failing every few months. I complained to the parts store that the u-joints they were selling me were wearing out to often. A wise parts guy(few and far between) looked at my u-joints and could tell I was using moly. Told me to change to lithium. Ended my problem, never replaced another.
Old Aug 2, 2009 | 08:13 PM
master_mechanic
With that said why does all the grease that meets ford spec have moly in it? ie Valvoline® Moly-Fortified Multi-Purpose Grease Ford, and Motorcraft premium long life grease.
Old Aug 2, 2009 | 08:35 PM
pjwoolw's Avatar
pjwoolw
As far as the Valvoline it is lithium based with some moly in there for good measure. The Motorcraft is just an all purpose moly. All around stuff. But I would use neither on bearings and u-joints. This stuff is just personal preference. Use what your comfortable with. As far as the Ford spec well................
Old Aug 3, 2009 | 09:01 AM
jimandmandy's Avatar
jimandmandy
There is some confusion here. Molybdenum disulfide (MoS2) is an additive. Lithium, or calicum or clay, is the thickener for the base oil that turns it into grease. The Ford spec is not moly grease, but lithium grease with moly added. Synthetic, semi-synthetic, or not refers to the base oil, just like motor oil.
Jim
Old Aug 3, 2009 | 12:10 PM
master_mechanic
Yes thats true sorry i worded that wrong... The grease i use has moly in it... But if this stuff is so bad for needle bearings why would they say that its good to use in u-joints? like to me the guys that make the product do tests and they should know what there product is good for.
