429 water pump question
Old Sep 7, 2007 | 07:33 AM
1947/67/77Ford's Avatar
1947/67/77Ford
I have just put togeter a 429 to go in my 68 4x4 and i realized I did not put the back plate (in between timing cover & water pump) to the water pump on, do I need to pull it off and put that in before I try to fire it up?
Old Sep 7, 2007 | 09:36 AM
airharley's Avatar
airharley
If you're missing the back plate it will over heat because the water pump wont be able to push the coolant. The back plate is kind of like a fan shroud for the radiator. It helps to channel the flow.
msp1972
Aug 24, 2010 05:04 PM
7mpg302
Dec 3, 2008 06:17 PM
tess100
Mar 11, 2004 12:10 AM
ohmanjd
Feb 6, 2003 08:02 AM
