Building a stroker EFI
Old Sep 7, 2007 | 06:29 AM
sibbles's Avatar
sibbles
Hello guy´s
I am in the process of building a 427 stroker out of 351 W EFI and would appreciate your input.
I´m wondering about what I would have to do to the EFI system. I´m most likely getting a whole kit with a cam that matches what I want from that car.
I have herd that the EFI system is airflow controlled so the more airflow I get through the sensor (to compensate for bigger cid) the more my computer will give of gas.
Any thoughts on the matter are well appreciated. Will post some pics when it all starts
Regards
Atli F.
Old Sep 7, 2007 | 08:33 AM
Kemicalburns's Avatar
Kemicalburns
read www.fordfuelinjection.com, check out http://www.flowmanagementunlimited.c...roducts_id=542
what are you dropping this motor into exactly, also try a search this topic has been covered
Old Sep 7, 2007 | 09:54 AM
Blurry94's Avatar
Blurry94
It'll fuel the engine as if it were still a 351w, without some type of aftermarket tuning. It'll most likely run lean with that much of an increase in cubes, under heavy throttle conditions.
Old Sep 7, 2007 | 02:09 PM
Conanski's Avatar
Conanski
Here are your minimum requirements..
An A9L or A9P mass air computer from an 89-92 mustang.
A big-assed mass air meter, 80mm for sure.
A Tweecer and a laptop.
A high volume intake like the Edelbrock Victor EFI.
30lb injectors.. maybe bigger, depends upon the cam and heads.
Toyman
2009 - 2014 F150
Oct 29, 2016 04:45 PM
Keeghan98
Engine Swaps
Mar 1, 2016 10:58 AM
Marty1092
Jan 26, 2014 01:46 AM
handsomerob
23
Mar 23, 2008 08:24 PM
blu93gt
Jan 29, 2002 08:42 PM
