Ecoboost airflow question
Old Oct 28, 2016 | 10:35 AM
Toyman's Avatar
Toyman
I'm really wanting to add a light bar in the opening on my truck. It is a 2014 with the little grill already in place, the light bar is 18". My thought was to take the grill piece out to have a little more airflow there, but also to cut holes in the lower bumper which falls right inline with the CAC. What do you guys think about that, am I asking for trouble?
This pic is where I'm thinking of using a hole saw to create more airflow.
Old Oct 28, 2016 | 04:07 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
If you take a look at the 2015+ trucks, they don't have the offset license plate or a gaping hole in the front end for the CAC and yet we hear nothing about airflow issues. Same engine set up, different body style.
Old Oct 28, 2016 | 04:14 PM
Toyman's Avatar
Toyman
Does the 15 have a bigger CAC though. I was looking at a 15 that came through the shop today and noticed the plate. Couldn't get a good look at the CAC while it was here.....
Old Oct 29, 2016 | 05:33 AM
tseekins's Avatar
tseekins
I'm really not sure brother, I've never been under the hood of a newer one. The CAC may have been redesigned to prevent the issues of the past.
Old Oct 29, 2016 | 05:59 AM
MCDavis's Avatar
MCDavis
The CAC in the 15+ is mounted higher.
A single row bar shouldn't be an issue. I wouldn't cram a full width double row in there. The stock CAC already struggles to keep intake temps within 20* of the ambient temps, and I wouldn't want that to change personally.
What are you looking to accomplish with the lightbar?
Old Oct 29, 2016 | 07:10 AM
Toyman's Avatar
Toyman
Looking for more light for deer camp. Have to travel down a 2 track about a mile. Also for the main roads, lots of animals running around.
Also don't want to add a windshield bar, it would be too awkward on this truck, not lifted huge cuz I pull trailers often.
Also why I was thinking I could put some additional holes in the lower plastic like I circled to make up for the airflow loss the light bar will take up.
Old Oct 29, 2016 | 07:25 AM
MCDavis's Avatar
MCDavis
Gotcha
I'm not convinced the lower holes will add airflow. Might want to look at Duallys or D2s from Rigid in the fog buckets. I have SAE fogs from them and they are very bright but I do understand adding light for deer etc.
check out this single row 10" from Rigid.
SR-Series 10" Midnight Edition Surface White Black... | Rigid Industries
It's 3750 lumens (about the brightness of OEM HIDs and twice and bright as a pair of Duallys) and its beam distance is 300 meters. Mounted low or high in the opening and it would likely blend right in.
Old Oct 29, 2016 | 07:32 AM
Toyman's Avatar
Toyman
That's the other side of it. I have an 18" light already (bday gift), I suppose I could always install it and see what happens to performance. Can always remove it and figure out what the 15's have for CAC after and in the mean time....
I'll have to follow up with what I find.
Old Oct 29, 2016 | 02:27 PM
MCDavis's Avatar
MCDavis
Or go with an aftermarket CAC. But thats a $1k decision.
Old Oct 29, 2016 | 03:18 PM
Toyman's Avatar
Toyman
I'll post up if anything changes.
Old Oct 29, 2016 | 04:28 PM
MCDavis's Avatar
MCDavis
Do you have a method/way to measure your temps?
Old Oct 29, 2016 | 04:42 PM
Toyman's Avatar
Toyman
I have AE software that I'll hook up when I head north in a couple weeks. I'll be able to monitor a lot with it.
Old Oct 29, 2016 | 04:45 PM
Toyman's Avatar
Toyman
I was looking online at intercoolers and pipes. I will probably upgrade all of that next spring. Should eliminate anything at that point, maybe even a tuner and exhaust before I start dragging the boat around next season too.
Mattsn
Nov 26, 2024 11:50 PM
snelldawg
Mar 1, 2018 01:42 PM
ansfdev
Dec 27, 2017 04:26 PM
northwindone
Jun 26, 2017 12:55 PM
txmoores
1978 - 1996 Big Bronco
Oct 23, 2003 09:51 AM
