checking trans fluid
Old Sep 6, 2007 | 03:57 PM
mustang_gt_350's Avatar
mustang_gt_350
I did the coonhunterjoe's shift kit a few days ago and really havn't driven my truck for a while. I checked the fluid and it was barely on the stick.
What drive selection should i have the shifter in when checking it? Should it be in P or in N?
Old Sep 6, 2007 | 04:23 PM
WMRiceman's Avatar
WMRiceman
Procedure is to check the level while in "P". Prior to checking, move the shifter through all positions. This is all done while the truck is running.
Old Sep 6, 2007 | 04:29 PM
mustang_gt_350
thanks.
Any tips for adding to it to keep the fluid that is in the dipstick tube from showing up on the stick? it takes forever to add and let it all drain down so that it doesnt get on the stick on the way in and out of the pan.
Old Sep 6, 2007 | 06:30 PM
JIM ROLAND's Avatar
JIM ROLAND
I would appreciate a tip on that also! I guess we will just have to go with the old but proven method:
pull,wipe,dip,pull,read,wipe,dip,pull,read,wipe,di p,pull,read,wipe,dip,pull,read,
wipe,dip,pull,read,wipe,dip,pull,read,wipe,dip,pul l,read,wipe,dip
Old Sep 6, 2007 | 08:18 PM
mustang_gt_350
the part that sucks the most is getting the fluid that hasnt drained down the whole way showing on the stick. But maybe thats why ford used the dimples maybe the fluid that touches the dip stick doenst touch the dimples?
Old Sep 6, 2007 | 08:39 PM
JIM ROLAND's Avatar
JIM ROLAND
I dunno? Could be!
Old Sep 8, 2007 | 03:24 PM
GoCamping's Avatar
GoCamping
Don't forget to have the tranny up to temp. The fluid expands as it gets hot.
Old Sep 8, 2007 | 07:48 PM
country2's Avatar
country2
I had the same problem and ended up checking it and driving over the course of 3 days I was finaly able to satisfy myself . It will definatly show in the dimples when it is at that level.
Old Sep 8, 2007 | 09:35 PM
kawika's Avatar
kawika
The way I saw Brian (of BTS fame) doing the dip stick check, was to just read it 4 or five times in a row and get a basis from that.
Make sure the truck is level.
Dave
Old Sep 9, 2007 | 01:28 AM
mustang_gt_350
I think i just now have it up to the level it should be.. I have to check it 1 more time then i will be happy.
