1978 - 1996 Big Bronco
Electric to manual help
Old Sep 9, 2007 | 04:23 PM
AEROSTAR ALIVE's Avatar
AEROSTAR ALIVE
It all depends on how "rebuildable" your core is, for the trans.
as far as axle, It gets HAIRY, but it can be done, but you will need several special tools.
Like an impact that can develop a ton of torque to seat a crush pinion. and then an inch pound torque wrench.
Be sure to get a bunch of pinion nuts and crush sleeves.
I would have two sleeves and two nuts on hand.
Then you need a dial indicator as well as a magnetic mount, and then oil based paste paint from an art store, to see pinion and differential "mesh". then maybe you could do a gear swap.
I think I seen kits on ebay for gear swaps. But Oreilly's had all the nuts and sleeves I needed to do mine.
Above all else, your side gears may be worn and need replacing, I would look into changing all that at once if needed.
altraditional
Jan 25, 2012 01:01 AM
drunkdave
Nov 17, 2008 04:52 PM
drunkdave
Nov 2, 2008 05:57 PM
Argo
Jul 31, 2004 07:13 PM
Big F250
Offroad & 4x4
Feb 14, 2003 08:49 AM
