302 EFI timing
Old Sep 6, 2007 | 03:08 AM
technomon's Avatar
technomon
302 EFI timing
ive got a 85f150 302 with EFI that i swapped out of a different truck this engine has a bad spark knock my question is does the computer set the timing or do i with a timing light or can it be that the other truck has a different computer allso i may have some vacume lines crossed the truck idles verry well but when giving it the gas it sounds terrible at any speed thanks
Old Sep 6, 2007 | 03:15 AM
HemiEater's Avatar
HemiEater
get the vacuum like where they belong and get a light on it to see where the timing is.....
Old Sep 6, 2007 | 04:30 AM
LxMan1's Avatar
LxMan1
Set it at 10 BTDC with the spout plug unhooked. This is the factory setting and seems to work best on EFI with 87 octane fuel. If your still having issues after thet, then I would check the fuel pressure. It should be around 30-32 at idle and 38-40 with no vacuum to the regulator.
Old Sep 6, 2007 | 11:18 AM
Bossman89's Avatar
Bossman89
I had this same issue but i bumped up the fuel octane for a week or so because i think i had some bad gas. I changed to a different fuel brand and it cleared right up. But checking timing would be a good idea to eliminate that possibility.
Old Sep 6, 2007 | 11:38 AM
blue beast's Avatar
blue beast
Check you knock sensor if it is disconnected or or the tiny wire in it is broke, Your computer will not know to adjust the timing. Disconnect the wire to it and put your multimeter set to millivolts on it and with a punch and hammer knock on the block, next to it. You should get spikes of voltage, If not take it out and tap on it if it makes voltage it should be alright if not replace that. The wires in it are tiny little things if it was bumped hard or dropped they could break.
aharleycpl
Jun 12, 2017 07:02 PM
Scott Glenn
Nov 22, 2016 03:24 PM
DeereFord300
Oct 9, 2016 07:40 PM
1994 302
22
May 19, 2016 05:16 PM
1995fordman
Jan 21, 2012 05:27 AM
