auto locker for front end?
Old Nov 12, 2010 | 09:44 PM
awq134's Avatar
awq134
has anyone found or installed an auto locker in the front end of their trucks yet. i have a 2010 stx 4x4 scab.
Old Nov 13, 2010 | 08:12 AM
msgtord's Avatar
msgtord
Did not like a locker in the front. Causes problems on slick roads, ice etc. Truck wanted to "crab". Best to only have air locker, or limited slip in front.
Old Nov 13, 2010 | 08:40 AM
awq134's Avatar
awq134
I don't plan on having the truck in 4x4 at highway speeds or anything close to that, but you did bring up a point that i really didn't consider before, thanks for the advice.
Q.
Old Nov 14, 2010 | 08:00 PM
kwissman's Avatar
kwissman
A locker in the front end will be troublesome. I have a locker in my rockcrawler and it is very hard to steer even on soft ground. I ripped the steering box off the frame trying to steer. The front tires need to be able to travel at different speeds anytime the wheel is not straight forward. It is also very hard on the front shafts. I would think it would twist off the shafts in the front end of the IFS like butter if it was in any kind of bind.
Old Nov 16, 2010 | 07:25 AM
msgtord's Avatar
msgtord
Q.
I'm talking about slow crawling across soft sand. the vehicle does not know which way to go. Like stated before, for a full on rock crawler, it works, but for anything less, it is a pain to handle sometimes. If you get an air locker, I'm sure it would be better, but you would find yourself unlocking it except in the most extreme conditions.
The best setup I ever had in my old Bronco was the factory Ford limited slip in the front, and a Detroit locker in the rear.
Old Nov 16, 2010 | 08:10 AM
MCDavis's Avatar
MCDavis
x2 on the limited slip or selectable locker in the front. Being fully locked, even with a Detroit Locker or another that will disengage on its own, is an absolute nightmare.
I've been in a fully locked Jeep on 35s in the snow, and it was downright scary when it came unlocked during shifts.
Old Nov 16, 2010 | 09:00 AM
samthelion's Avatar
samthelion
Have a look at powertrax.com . they build a unit that only ENGAGES when needed. I have one in the rear and the design seems that it would lend itself usable in the front.
Old Nov 16, 2010 | 09:43 AM
stephen.osborne1's Avatar
stephen.osborne1
X 2,000,0000- Do not put a traction device in the front differential of an IFS truck... Every bump that cycles the suspension causes the tires to travel at different speeds. You will tear out your half shafts QUICK. This is even when going in a perfectly straight line! Turning only makes this worse! DON'T DO IT!
Old Nov 16, 2010 | 12:23 PM
awq134's Avatar
awq134
thanks everyone for the info, maybe i'll just go for the air locker in the rear and call it a day.
Old Nov 16, 2010 | 08:26 PM
msgtord's Avatar
msgtord
You will really like the air locker in the rear. You'll find yourself playing around and seeing just how bad you can get stuck then hit the button and drive out in 2 wheel drive.
With just my Detroit locker, I went most places and never engaged 4 wheel drive. I have pulled people out of a deep sand pit, then backed into the hole, buried it in 2 wheel drive, then drive out after putting it in 4x4. I figure the air locker would be much better. The only bad thing about the Detroit locker was getting the rear end additive just right to keep it from locking up around a corner on dry pavement. Makes a hell of a racket for sure.
Good luck.
TractorM3
2015 - 2020 F150
Dec 13, 2015 04:29 PM
docsuby
Nov 28, 2013 12:52 PM
F-250 WARHORSE
Aug 13, 2012 11:01 AM
tbaker00
6.7L Power Stroke Diesel
Jul 4, 2010 01:55 PM
quisp-n-quake
17
Nov 3, 2007 10:58 AM
