Sway Control
Old Sep 20, 2007 | 11:52 AM
tfalk's Avatar
tfalk
Originally Posted by avmike
In order of effectiveness, (and cost) they are:
1. Hensley Arrow
2. Reese Dual Cam
3. Equal-izer
Since the original question was about sway control, I would switch your #2 and #3.
The Reese Dual Cam is a load distribution hitch - it has no anti-sway mechanism
by itself unless you add the friction sway control device to it.
The Equal-izer is a weight distrubtion hitch that also has built-in sway control.
I've used both and prefer the Equal-i-zer.
Old Sep 20, 2007 | 02:42 PM
Gene W's Avatar
Gene W
"Since the original question was about sway control, I would switch your #2 and #3.
by itself unless you add the friction sway control device to it."
That is incorrect. The Reese Dual Cam Hitch provides both weight distribution and sway control in one device that doesn't need to be readjusted for backing or weather conditions like the friction systems do.
The friction of the dual cam device provides sway control by locking the tow into a straight line. The force generated by turning the rig will cause the spring bars to pop as they slid over the cams. It works better than friction type anti sway devices in my opinion. The cams or the matting portion of the spring bars should not be lubricated on a dual cam hitch as it will lessen the anti-sway properties of the hitch.
Gene
Old Sep 20, 2007 | 05:03 PM
tfalk's Avatar
tfalk
OK, I just went to the Reese site. The system I had previously was called their
Dual Cam Hitch with the trunnion bars. It looks like they changed it to now include
what they call "Dual Cam High-Performance Sway Control " if you order the package setup.
The dual cam hitch by itself does not have any sway control, you have to order the package
or buy the dual cam hitch and later add the sway control setup.
I think the Equalizer setup is easier and it works for me. It also doesn't need to be adjustedd
for backing up or for weather. YMMV...
Old Sep 20, 2007 | 06:32 PM
Gene W's Avatar
Gene W
This is what you probably had before. They also made them with square spring bars without the humps in the end many years ago.
"Draw-Tite Trunnion Bar Weight-Distributing Hitch Systems"
http://www.reese-hitches.com/WD/dt_trunnion_bar.html
The last two illustrations on this page show the two variations of the Dual Cam system.
http://www.reese-hitches.com/sway_controls.htm
The type you had is upgradable to the dual cam system and uses all of the same parts, including the same spring bars that have the humps in them to ride on the cam type chain hangers and provide the sway control. You can also use the friction sway control along with the complete dual cam system but I don't know why anyone would want to.
Same parts, but without the cams in the chain hangers it isn't a dual cam hitch.
The Equalizer hitch does look easier to hook up although after the initial installation of the Dual cam (which is a lot of work) it's fairly easy to hook up as well.
Gene
Old Oct 29, 2007 | 11:23 PM
jteller's Avatar
jteller
We are about to go from a smaller Fleetwood PUP trailer to a 31' TT and this has been a useful thread. I think I'm going with the Equalizer hitch... Thanks.
Snowseeker
Mar 18, 2013 08:50 PM
tsbrewers
Feb 23, 2012 07:13 AM
ydaveitsu
Jun 24, 2011 01:17 PM
Delzell
24
Apr 7, 2007 10:32 PM
damone
All Things Towing
Mar 26, 2004 04:53 AM
