sway control
Old Mar 18, 2004 | 07:24 AM
damone's Avatar
damone
sway control
I am considering the purchas eof a Toy Hauler. 24' 5600lb UVW. I am also considering a 21' 4900lb UVW, anyway. I will be towing with an 03' Expedition and was wondering what is more improtant when considering the use of sway control; length ot weight?
At what length/weight should I purchase sway control.
I already have purchased a EAZ Lift WD system.
Thanks,
D
Old Mar 18, 2004 | 08:23 AM
jim henderson's Avatar
jim henderson
Not sure what UVW is, Unladen(?) vehicle weight? If is is the empty weight keep in mind cargo weight adds up much faster than the eyeball can figure. Depending on what you drive, the empty trailer may already be at or above your rated maximum for the truck. When you add cargo it gets worse. So let's hope you are talking F250 or bigger.
Longer trailers tow better in my opinion. Weight isn't as big an issue in itself. Balance of the weight is much more important. Assuming a regular hitch type trailer, you want 10-15% of the total weight of the trailer on the hitch. If too little weight is on the hitch, the trailer will get squirrly. Too much and handling will get sloppy.
I would probably get a sway bar with your weight. It will make any trip much more relaxed since you won't be needing to do as many steering corrections. I assume you have a weight distributing hitch.
Good Luck,
Jim Henderson
Old Mar 18, 2004 | 08:24 AM
fellro86's Avatar
fellro86
My experience has been that if you load the trailer right, meaning not heavy on the tail, and with the weight dist. hitch, you won't need the sway bar, but that's my experience.
Old Mar 18, 2004 | 10:54 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
If you have the EAZ Lift WD system, I would wait until you get your trailer. Then take a little shake-out trip to see how it handles. A WD hitch goes a long way towards eliminating a lot of the causes of 'sway'. So you may not actually need a separate sway control.
Old Mar 18, 2004 | 11:36 AM
damone's Avatar
damone
Thanks for the replies. I will do the test run and see how it goes.
When loaded including hitch weight my tow vehicle is at it's GVWR of 7300lbs. That leaves 7200lbs towing capacity. The GCVWR is 14,500.
I have done the math and have considered all ratings. I have accepted that I will be towing at my ratings and will upgrade when I can.
Appreciate any other replies as well.
Old Mar 19, 2004 | 05:43 AM
msmarcus's Avatar
msmarcus
Before a trip with my 24' car hauler, I purchased a friction type sway control (about $70) and installed it. I use a WD hitch and was towing about 7000lbs. I had NO trailer sway for the entire 20 hour trip. Not sure that I would have with out, but $70 was cheap peace of mind and made the trip very enjoyable, although I spent 4 weeks up to that point worrying myself silly reading posts on this website about trailer sway. Like the boy scouts say, be prepared.
Old Mar 24, 2004 | 08:50 AM
damone's Avatar
damone
4 weeks. Thats nothing I've ebeen reading for 8 weeks and havn't even bought the trailer yet.
Thanks for the reply.
Old Mar 26, 2004 | 04:53 AM
missouguy's Avatar
missouguy
I run a Reese Dual Cam sway control with the Reese W/D hitch. It is really a nice setup. I pull a 33' TT with the F-250 460 E4OD. Never had any sway. If you have a W/D hitch already the Reese dual cam is only about 150 bucks.
Frank
Robert1000
All Things Towing
19
Jun 8, 2010 05:34 AM
JRCF
May 29, 2008 10:46 PM
the4by4freek
All Things Towing
16
Jan 24, 2008 07:48 PM
shenders99
Jul 1, 2007 01:34 PM
damone
21
Mar 12, 2004 08:16 AM
