Determining Towing Capacity
I’m going to be buying a 2003 F-150 SuperCab for my primary truck and to tow a RV. I want to find a truck that has the maximum towing capacity for that year and model.
According to my trailer life towing table, that is 8,500 lbs in a truck with the following:
5.4L V-8, 3.73:1 axle ratio and 7,700 payload group A,
OR
5.4L V-8, 4.09/4.10:1axle ratio and 7,700 payload group B.
My question is, how do I verify what axel ratio a truck has and how do I determine it has one of the 7,700 payload groups?
Thanks for your help,
Bill.
You can check the tag on the axle for which gear ratio it has. 7700's are not that common and I think most are set up with 3.73 rear ends. The code on the door frame will also tell you what it has. When you find one with 7 lug wheels you are finding what you're looking for.
Looks like you will need to find one with 4.10 gears that is included in the 2wd "Available with 7700 payload "Plus" Group B only". This will get you an 8600lb towing capacity. Sounds like you are borderline in need of a SuperDuty.
Knowing ahead of time what the loading might be for towing often, is not wise to use the weight rating limit as a absolute guide without condering a diesel motor for the much better performance it will give..
When you get out and tow at those high loads, you may have second thoughts.
Question is what will the gross combined weight be and not just the rating of the truck because you have to pull all the weight.
I tow at GVW as high as 12,000 lbs with a 4.6/3.55 combnination . While it does an admiral job, it's not the worlds fastest on the hills and is the time I could use more truck in the power department.
Just another way to look at it.
Thanks again.
Bill.
