a/c smells like coolant
Old Mar 7, 2013 | 09:49 PM
  #31
Kevin 1988's Avatar
Kevin 1988
Originally Posted by jfriesen
Thanks guys for the information. So if I have 2 heater cores would it be smart to replace both as the repair is a bit labor intensive? Also I was reading and came across an article where someone indicated that a brass/copper aftermarket heater core should be used when replacing. Anyone able to chime in on that?
I think the other heater core is in the back of the truck an as far as using a brass core i don't see the point as long as you use the right anti freeze you won't have any problems the heater cores go out from abuse by that I mean not keeping up on ur preventive maintenance
Old Mar 8, 2013 | 08:13 AM
  #32
BAD RONALD's Avatar
BAD RONALD
Do the pressure test to verify the leak. Autozone will loan tools for free if you don't have what you need. Repair the leak that you find.
You are over thinking matters here by worrying about the rear core. If it is leaky it is a separate job.
Purchase the best available parts you can afford from a vendor you trust. Responsibly maintain your cooling system going forward. Do a thorough search of this board and benefit from the experience of others.
For me, the hardest part of this job was moving my fat a$$ away from the keyboard and getting started.
Old Mar 8, 2013 | 10:03 PM
  #33
alloro's Avatar
alloro
Just the opposite is true. Aluminum heater cores and radiators transfer out heat much better than the copper or brass ones do.
mebe2k
6.7L Power Stroke Diesel
Nov 14, 2014 10:11 PM
stonefinder1
Oct 16, 2014 01:28 PM
f1501987
Sep 8, 2012 07:03 AM
wolftan
18
Mar 11, 2007 07:13 PM
Katt
May 7, 2001 09:00 PM
