a/c smells like coolant
Old Sep 12, 2007 | 09:38 PM
Mark62's Avatar
Mark62
My Guess is $600.00
Old Sep 13, 2007 | 07:54 PM
Libra's Avatar
Libra
Heater core, great that is probably what is wrong with mine right now. Coolant smell coming out of the vents when I have the heat on.
Old Sep 14, 2007 | 05:55 PM
mack6820's Avatar
mack6820
Im gonna pull it this weekend and see what happens. Guess I need to stretch first. hehe
Old Sep 15, 2007 | 10:02 AM
bmconway76110's Avatar
bmconway76110
Got mine back. It was $637.00. The mechanic was nice and told me to bring it back it I hear any rattle, but I have already gone 100 miles and haven't. However, my adjustable break pedal don't work now, so I taking it back next week. The switch doesn't light up so I guess the switch didn't get plugged back in.
Old Nov 4, 2007 | 08:31 AM
mack6820's Avatar
mack6820
Well I got the dash COMPLETLY torn apart after 2 days and lots of words. I still cant get the dash out!! Id love to meet the guy who put the heater core in the schematics. What a retard!!
How the heck am I gonna ever get this thing back together. Ive removed about 200 screws now and 50 electrical plugs.
Old May 19, 2010 | 01:10 PM
uptownkevin's Avatar
uptownkevin
Heater Core Option
Thanks for all the info on the Heater core , I had the same problem , after reading how much is involved in replacing , I decided to by-pass the heater core. Just cut one of the lines and splice it to the other with a brass 1/2" hose splice and clamps. I live in the desert so I can live with-out heat , this won't work if you live up North but could be a temporary fix for some.
Old May 20, 2010 | 06:55 PM
Moto Mel's Avatar
Moto Mel
You really ought to reconsider cutting those hoses as they get pretty expensive. Live with the pain and change the heater core.
Old Jan 23, 2013 | 12:08 AM
DaRedNeckKing's Avatar
DaRedNeckKing
2002 Antifreeze Smell!!!
200 Screws???? Major Headache!!! I gotta get mine checked out.. Smell antifreeze but windshield not fogged up..
Old Mar 6, 2013 | 04:32 PM
jfriesen's Avatar
jfriesen
Ok so I am running into this issue as well in my 99 Expy EB. Same symptoms, smoke/exhaust coming from vents that smells of coolant. Unfortunately, I can't afford to take it to the dealer right now to have the heater core replaced. So I am planning on doing the replacement myself when it gets a bit warmer outside (no garage and live in Central MN). My question is two part; 1. does anyone have any good documentation for doing the heater core replacement yourself and 2. I am thinking about cutting the inlet/outlet lines to the heater core and coupling them together. Also I am seeing 2 sets of houses (left of the engine on the firewall) which set specifically goes to the heater core. Any thoughts regarding this?
Old Mar 6, 2013 | 08:50 PM
c_hohensee's Avatar
c_hohensee
If you are going to tackle the job I would recommend subscribing to helm online for 72 hours to get the correct info to do the job. If you are seeing 2 sets of lines it could be because you have rear heat and air. I live in twin cities myself and would not want to work outside now with all the fresh snow.
Old Mar 6, 2013 | 09:22 PM
Kevin 1988's Avatar
Kevin 1988
Originally Posted by Billykidd
Same thing just happened to mine! Another thing it started to do is my gauges, lights, instrument panel, and electrical systems are going crazy! RPMs will spike during idle and eventually it will just stall and won't be able to start....dead batter!? I can jump it but it will just do the same thing and eventually stall again?
I'm thinking heater core for yours and mine but any ideas on the crazy dash and electrical system? Is it possible coolant is shorting out the system and causing everything to go crazy?
Hey check on the passenger side there's a tube that goes into ur intake it's right above the last spark plug it's probably leaking an wetting the plugs I just had the same problem with my 99
Old Mar 6, 2013 | 09:34 PM
Kevin 1988's Avatar
Kevin 1988
you have two heater cores one set is for the front heater core an the other is for the rear
Old Mar 7, 2013 | 07:34 AM
  #28
BAD RONALD's Avatar
BAD RONALD
So I am planning on doing the replacement myself when it gets a bit warmer outside... does anyone have any good documentation for doing the heater core replacement...
Watch this video to get an idea what you are in for. Search this topic on this board and you will find a ton of detail on the procedure. If you have the time, patience and are organized this is an inexpensive repair to do properly.
Old Mar 7, 2013 | 07:46 AM
  #29
BAD RONALD's Avatar
BAD RONALD
Read this http://motogrrl.com/blog/wp-content/...CoreRepair.pdf
I saved $900 a few years back using the video and this pdf.
Old Mar 7, 2013 | 08:34 PM
  #30
jfriesen's Avatar
jfriesen
Thanks guys for the information. So if I have 2 heater cores would it be smart to replace both as the repair is a bit labor intensive? Also I was reading and came across an article where someone indicated that a brass/copper aftermarket heater core should be used when replacing. Anyone able to chime in on that?
