79 400m noise
Old Sep 5, 2007 | 09:06 AM
polky's Avatar
polky
79 400m noise
79 4oo m heads just rebuilt. but the driver side side make a tapping noise and noise is louder behind front tire towards the tranny. exhaust smokes when engine been running for awhile. when i give it gas and rpms climb it sounds like a deisel truck for some reason? i'm lost. all plugs and wires, cap and rotor replaced. help!!
Old Sep 5, 2007 | 09:36 AM
beartracks's Avatar
beartracks
The first thing I would do is remove the valve cover on the right side and do a visual inspection before damage is done. Also recheck timing and firing order.
Old Sep 5, 2007 | 08:23 PM
danlee's Avatar
danlee
What color is the smoke?
Pull the plugs on that side look for any that are real dark, or real light.
Old Sep 6, 2007 | 07:55 AM
polky's Avatar
polky
smoke is white, took valve cover off everything looks good. timing is 14 before correct? i does idle a little rough, could it be worn a cam?
Old Sep 6, 2007 | 08:05 AM
danlee's Avatar
danlee
White smoke is water vapor, while blue is oil, black is fuel.
Check the color of the plugs, and do a compression test.
Old Sep 6, 2007 | 10:01 AM
beartracks's Avatar
beartracks
White smoke could also be tranny fluid if the modulator is ruptured. It would suck tranny fluid into the manifold.
Old Sep 6, 2007 | 07:06 PM
danlee's Avatar
danlee
Good call, that seems to fit the symtoms.
Old Sep 7, 2007 | 07:52 AM
polky's Avatar
polky
Its A 4-speed, Where Would The Fluid Come From? I Smell Gas Fumes Really Good While Driving, Does This Mean Anything? JUST CHECKED PLUGS #5 CYLINDER IS BLACK REST LOOK BRAND NEW. COMPRESSION IS FINE. WHEN HEADS WHERE REBUILD THIS CYLINDER NEEDED VALVE REPLACED NOT SEETING. WHAT WOULD CAUSE THIS?
Old Sep 7, 2007 | 10:17 AM
beartracks's Avatar
beartracks
The tranny fluid reply is only for automatics.
It would appear you have identified the problem area. I would look closely at the valve geometry for that cylinder. Make sure the push rods are seated and are not too long as they are not adjustable without shims or different rods.
If the valve is held open it will burn. Also make sure you have spark to that plug.
Good luck.
Old Sep 7, 2007 | 11:32 AM
danlee's Avatar
danlee
If the plug is wet with fuel, it means that the cylinder isn't firing.
That could be low compression or no compression or no spark. You should have seen a problem with that cylinder when you took the compression test. Check your plug wires and your firing order again.
Old Sep 7, 2007 | 01:29 PM
polky's Avatar
polky
I'll Try That
Old Sep 7, 2007 | 04:34 PM
2classics's Avatar
2classics
compression good, black plug means it's firing, but possibly rich? Could it be a problem with the exhast valve not opening far enough/long enough? Sounds like a valvetrain problem, only being on one cyl.
Old Sep 8, 2007 | 08:06 AM
polky's Avatar
polky
the 2nd rocker in seems loose to me. when torned apart all the lifters where moving fine. could it be a bent rod? bad cam lope? any tips to fine out? not sure what else to do.
Old Sep 8, 2007 | 12:49 PM
2classics's Avatar
2classics
The tapping noise might be a pushrod and rockerarm slapping together. You will have to take out the rods and measure to make sure they are thee correct length, and roll them to see if they are bent. Look at the rocker to see if the contact pattern looks good.
Old Sep 11, 2007 | 08:07 AM
polky's Avatar
polky
someone told me that it may be the bearing. he says 351-400m are known for oblonging the crank. anyone else have this problem?
prime81
6.7L Power Stroke Diesel
26
Oct 30, 2016 10:16 AM
lmarkie
1997 - 2003 F150
24
Feb 25, 2016 01:16 PM
racin
1997 - 2003 F150
Jan 14, 2016 10:17 PM
rvpuller
All Things Towing
Oct 15, 2015 09:27 PM
F350Man79
Jul 28, 2014 07:59 PM
