Decelerating idle speed
Old Sep 5, 2007 | 07:19 AM
wickedxter's Avatar
wickedxter
im having strange thing with my 5 Speed. When decelerating not down shifting and coming to a stop the idle stays around 1000-900 rpm's and when I come to a compleate stop it goes to idle. I seems like something is geting stuck open, but what I dont have a clue about.
Old Sep 7, 2007 | 01:08 PM
BrianA's Avatar
BrianA
A bit confused
5 speed manual, right?
Are you coasting to a stop? With the clutch in?
I think what you describe is normal but the details are a bit sketchy.
Old Sep 7, 2007 | 04:56 PM
wickedxter's Avatar
wickedxter
yea costing to a compleate stop the idle speed stops around 1000 rpm's then once stoped it drops to idle 800-850.
Old Sep 14, 2007 | 09:40 AM
heyjero's Avatar
heyjero
Higher idle while in motion
I believe this is by design. My guess is that the IAC opens a little while decelerating to improve MPG. By reducing the vacuum, there is less drag on the engine - allowing you to coast further (assuming you had it in gear).. You can notice it does this while above a set speed. Coast down a long hill and the RPM will by slightly raised until you come to a stop...
F100Mann
Jul 23, 2014 01:43 PM
mulvaney324
1997 - 2003 F150
Aug 25, 2011 09:04 PM
dcr5468
1997 - 2003 F150
Sep 18, 2008 04:43 PM
cardude
Dec 18, 2001 05:13 PM
zemus420
Dec 1, 2001 05:08 AM
