Sponsored by: Auxito
Extreme Vibration when decelerating?
Old Aug 15, 2011 | 08:00 PM
mulvaney324's Avatar
mulvaney324
I have the acceleration vibrations that seem to be common, but I have recently developed an extreme vibration upon deceleration. It is more severe at higher speeds than at lower speeds. When I take my foot off the pedal at 70+ the whole truck feels like its going to come apart. Any ideas?
Old Aug 15, 2011 | 08:02 PM
ford390gashog's Avatar
ford390gashog
Sounds like a Torque converter issue to me!
Old Aug 15, 2011 | 08:27 PM
steve(ill)'s Avatar
steve(ill)
If it is that bad, the first thing i would do is jack up one front tire a couple inches (under the a-frame) so one tire is just off the ground. Grab the tire one both sides and try to jerk it left and right. See how much it moves. Look under the truck to see if the tie rods , ball joints or, steering anchor are moving sugnificantly. Put a 2 x 4 about 3 ft long under the tire and pry up and see how much up and down it has.
Old Aug 15, 2011 | 09:41 PM
Bluegrass 7's Avatar
Bluegrass 7
At speed slip the shift into neutral and note any difference with the driveline disconnected.
.....What happens when you suddenly lift power off the throttle the converter lockup comes off and your back to just the converter slip coupling.
.....The PCM program is programmed to do this, then go back to lockup after a short time. There is a reason this is done. If you have a tach you can see the rpm rise about 300 rpm with application of light throttle then settle back when lockup come back on.
.....If it's still there after shifting in neutral the trans or driveline is suspect.
Good luck.
Old Aug 21, 2011 | 03:04 PM
WebbySupercrew's Avatar
WebbySupercrew
I hope I am not hi-jacking the thread but I am wondering what the acceleration vibration you talk about is? I have it on my '01 supercrew and have been searching for days on here to figure out what it is? Front end, rear end? U-Joint? Thanks all!
Old Aug 24, 2011 | 08:41 AM
WebbySupercrew
No body???? Any body?
Sorry for the bump.
The vibration is between 0-5mph or so.
Old Aug 24, 2011 | 11:08 AM
Bluegrass 7
Until somebody comes back with some results from testing to get some direction, you will have to use a crystal ball for answers.
There are so many possibilities for the causes and yet people want to be told exactly.
Old Aug 25, 2011 | 03:42 PM
WebbySupercrew
Originally Posted by Bluegrass 7
Until somebody comes back with some results from testing to get somwe direction, you will have to use a crystal ball for answers.
Oh it's not neccesarily that I want to be told exactly what it is, just kinda a few problems it "might be"
In the OP he stated
And since I have it there may be someone to shed some light on this "common" occurrence.
For me it is an extreme vibration that seems to come from the rear end that all start from a dead stop up to about 5 mph.
Old Aug 25, 2011 | 09:04 PM
steve(ill)'s Avatar
steve(ill)
web, are you going straight ahead, or are you turning sharp from a stand still when you get the vibration ? Limit slip rear end can drag and cause jumping during sharp turns at low speed.
ExPACamper
58
Mar 9, 2017 08:37 PM
chaindog
19
May 7, 2006 07:54 PM
jhromy
Apr 12, 2004 02:16 PM
deafdane
Aerostar
Jul 18, 2003 11:31 AM
Pastmaster
Apr 7, 2002 07:37 AM
